Question about Sharp EL-2630P Calculator
Print colors are reversed--negatives in black; positives in red
How do we fix this?  How did it happen in the first place?
Does it come with an ink ribbon? If so, it's in upside down.
Posted on Jan 07, 2008
1983 Ram Van. Where can I get a radio wiring diagram?
1983 Dodge Ram Van Audio Wireing Chart
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Black/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Black/Red
Mar 27, 2016 | Dodge Cars & Trucks
What is the negative and.positive pin on the battery?
The battery terminals have a plus (+) and minus (-) symbol somewhere near the terminal studs. If you cannot find them, use a multimeter set to a proper DC Range. Place the probes on the studs. If the meter reads the voltage, then red probe is on the positive terminal, if the meter pulls backwards the black probe is on the positive terminal.
If using a digital multimeter, a (-) says that the red probe is on the negative terminal.
Mark your battery with a Sharpie somewhere to show the terminal studs.
Mar 03, 2015 | Cars & Trucks
HDS Gens Touch shows positive red to negative & black to positive?
Lowrance may have goofed on the manual printing. RED is Positive, Black is negative. All these systems have reverse polarity protection. If you wire backwards, the screen will flash on and then automatically turn off.
I install these systems and I have always put the fuse hlder on the positive line at the battery. The fuse holders are always red wires and that may also lead to some confusion if they suggest attaching that to the black lead.
Hope this answers your question.
Jan 05, 2013 | Lowrance 000-10767-001 Hds-9M Gen2 Touch...
55973 A EVINRUDE Wiring Diagram IN COLOR FOR Free
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Nov 14, 2012 | Clymer Boating
I am installing a CD player in a 2004 Nissan Sentra and I need to find the wiring diagram to show me how. Can you help?
see connection colors below and let me know if you have questions.
2004 Nissan Sentra wire colors aftermarket radio wire colors
Car Radio Constant 12v+ Wire: Pink, yellow
Car Radio Switched 12v+ Wire: Blue, red
Car Radio Ground Wire: Gray, black
Car Radio Illumination Wire: Red/Green, N/A (tape off factory wire)
Car Stereo Dimmer Wire: Red/Yellow, N/A (tape off factory wire)
there is no factory amplifier wire, blue (tape off radio wire)
Left Front Speaker Positive Wire (+): Pink, white
Left Front Speaker Negative Wire (-): Blue, white/black
Right Front Speaker Positive Wire (+): White, gray
Right Front Speaker Negative Wire (-): Black, gray/black
Left Rear Speaker Positive Wire (+): Light Green, green
Left Rear Speaker Negative Wire (-): Violet, green/black
Right Rear Speaker Positive Wire (+): Blue, violet
Right Rear Speaker Negative Wire (-): Pink, violet/black
Aug 21, 2011 | Car Audio & Video
How do I hook up the bare wires speakers to the back, sound is coming out not good.
Sounds to me like you might have the polarity reversed. Meaning you might have hooked the positive to negative and the negative to the positive. Positive will will be red negative will be black on your receiver. On the speaker wires negative will always be solid black. Positive could be solid red, black with a red stripe, or black with any color stripe. Make sure you have solid black hooked to black and the other hooked to red. Hope this helps:)
Nov 30, 2009 | Insignia 200W Stereo Receiver
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
Need a stereo wire color code for 2000 subaru outback limited
The sell a nifty little invention at Wally-World. Its called a wire harness...look for it in the auto parts section. it will wire directly to your stereo wires and then just plug & go... if your subaru wires are missing the harness on the end, its a whole different ballgame, and its gonna be fun...try this...
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Green
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Green/Black
Right Front Speaker Positive Wire (+): Red/Yellow
Right Front Speaker Negative Wire (-): White/Black
Left Rear Speaker Positive Wire (+): White/Red
Left Rear Speaker Negative Wire (-): Red/Green
Right Rear Speaker Positive Wire (+): Blue/Green
Right Rear Speaker Negative Wire (-): Red
Let me know how it goes!
May 17, 2009 | 2000 Subaru Outback
Help..
Yes aslong as the two wires are not connecting each other. white is the positive and the black is the negative. It's better if you use a voltmeter if you don't want to guess.. connecting the voltmeter to the wires. if the voltmeter goes left or did not respond reverse the test prodes or test pins, if the volt meter show 3-6 volts, look at the color of your testprodes. red is positive and black is negative.
Jun 07, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Labtec LCS 1024
I don't have a wiring diagram for you but can tell you this as standards apply.
Red is always the positive (+) terminal and black the negative, ground, (-) terminal. FYI-though people use the term ground it is not correct.
Another thing you should know is red and black are relative. Inother words, when red to red and black to black it will cause an outward motion of the speaker. If you happen to reverse them, red to black, it just causes an inward motion of the speaker. Sometimes this is refered to as the "phasing" of the speaker.
Speakers are usually marked at their connection points with a red dot or a (+) for the positve and a black dot or (-) for the "negative" side.
So there's nothing to worry about if this happens anyway except:
if you were to go red-black on one speaker, and red-red on the other. This will cause the speakers to be in series which normally wouldn't hurt things, but make sure it's not done just in case you amp section cannot tolerate this condition.
Hope this helps.
Jeff
Mar 19, 2008 | Labtec LCS 1024 Computer Speakers
Sharp EL-2630P Calculator Logo
155 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
