Question about Frigidaire PLEF398AC Electric Kitchen Range
ABOUT HOW MUCH DOES AN EOC COST AND IS IT WORTH FIXING?
  • 111 Answers
Make and model# please
Posted on Jul 13, 2009
2 Suggested Answers
  • 63 Answers
SOURCE: F1 problem and cost of replacement
Approximately $200.00. Plus tax and shipping.
Posted on Sep 12, 2009
F11 error persists after powering down and back up. Model 79047783403. Does the EOC need to be replaced and can I do this myself?
Hello;
My name is Peter. I am a retired field service appliance technician.
The error code generally indicates either you have a bad oven thermocouple or the EOC is bad.
First, remove the thermocouple through the back.
25656710-5ds3gtdzu2lsmxhybqelrkoe-4-0.jpg Part #: 316217002 Cost: $32.00
With a multi-meter set the meter to the lowest Ohms. Insert the two probes into the two contactors. You should get a reading between 1000 - 1100 Ohms if it is good.
If this is good then you have a bad EOC board.
25656710-5ds3gtdzu2lsmxhybqelrkoe-4-2.jpg Part #: 316418554 Cost: $190.00
When replacing make sure you ground yourself by rubbing your hands on bare metal. Static electricity will knock out a control board.
The part cost is based on Sears cost. Search the internet for the part numbers, you can get these parts for less.
Apr 20, 2015 | Kitchen Ranges
I AM GETTING F1 ERROR CODE ON FRIDIGEAIRE MODEL #CFEF372CS2 SERIAL # NF41924422, ONLY OVEN NOT WORKING
I am 99% positive you need a new EOC based on the fact that you said you heard the all too common pop noise. EOCs usually cost around $200-$300 and sometimes more. The EOC in this is the same as your clock, if you took off the top back you will see burn marks on the back of the clock.
Jul 04, 2014 | Frigidaire PLEF398AC Electric Kitchen...
How can we turn off oven cooling fan after use> It runs forever after use and oven is at room temp but fan keeps going
The cooling fan is controlled by the EOC and a temperature sensor located at the top of the oven near the control panel. If the temperature is above a 100 degrees there the cooling fan will continue to run. If it does not turn off when the temperature goes below this, there is a problem with either the EOC or temperature sensor. Try turning off the power to your oven for at least an hour to reset the EOC, this may fix the problem.
Regarding the shelves being 1/4 short, this is actually caused by your oven liner expanding not your shelves shrinking. The only fix for this is to have your oven liner replaced.
Both of these repairs are very expensive ( > $300) and may not be worth fixing.
May 14, 2014 | Kenmore 46123 Stainless Steel Electric...
F1 on screen
F1 means the control (EOC) has failed. Try leaving the power off to the range for as long as possible (overnight). If the problem persists the EOC would need to be replaced. This part can cost over $300.
Apr 18, 2014 | Kenmore Kitchen Ranges
We are geting a F 11 code on this Model number plgfmz96ecc
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11
Shorted Keypad.
1. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
Jun 13, 2011 | Frigidaire PLES399EC Electric Kitchen...
Have a whirlpool gold black oven and nothing works on the electronic oven control panel but the burners on top work. what could be the problem? thanks, dan
Hello Dan. You most likely need a new EOC (oven control) / clock. These are often expensive but fairly easy to change. If you do decide to try to replace it BE SURE that it is unplugged or the breaker is off. Usually if you pull the range out from the wall (be careful of scratching your floors, put cardboard under the front legs) you can access the EOC from the back of the control panel. There should be a cover over the back of the control with a lot of screws, remove as many as you need to have access to the EOC. It should be evident how to remove the EOC once you see it, often just 4 screws. Have the new one on hand and just be careful when removing wires and make a little diagram if you need to help you remember where they go on the new unit. One thing to consider once you get the cost of the EOC/Clock take a look at the cost of a new range. Sometimes these parts are half the cost of a new range. Hope this helps, best regards.
Sep 27, 2010 | Whirlpool Ovens
Sep 12, 2009 | Frigidaire Gallery GLEFM397DS Electric...
F6 ERROR CODE ON MY FRIGIDAIRE STOVE.
dagadier
We may be able to repair your EOC, what are the symptoms?
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Stove replacement?
All the fault codes I could find on Roper indicates that this is an Electronic Oven Control (EOC) failure. This is your clock assembly. Searspartsdirect.com carries the part for about $47. I think for that price, it may be worth the attempt to repair the range, vice replacing one at a cost of hundreds of dollars. Just type in your model number and you can locate the clock assembly under the "Backguard Section" heading as item number 17 (part number WB27M10). I hope this helps you.
Aug 17, 2008 | Roper FGP325K Gas Kitchen Range
Jenn- Air SCE30600B
It's a bad capacitor on the clock/display board. The solution was posted elsewhere in FixYa. I had the same problem and was told I should replace the clock/display board, which would solve the problem, but costs about $150 plus labor. If you can desolder/solder small components on an electronic circuit board, you can fix this yourself. Mine was capacitor C3, originally a 68uF 35V component. I replaced it with a 68uF 63V as the closest one I could find at Jameco.com which was less than a $1. Lo and behold, my clock/display is back to normal! Saved a lot of money to fix it myself and I know it will happen again over time, so I know exactly what to do next time.
Jan 25, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Frigidaire PLEF398AC Electric Kitchen Range Logo
689 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
