Windows cannot access the specified device path or file. You may not have appropriate permissions.What's annoying about this message is that sometimes it has nothing to do with permissions at all! Here's a couple of possible ways to fix it, depending on your system.Method 4 - Real permissions issue Finally, you may actually have a permissions issue. In this case, make sure you are an Administrator or you are part of the Domain Admins group if you are in a domain.
Note: First, restart your computer in Safe Mode (only XP and Vista) and see if you can open the file or programs in question. If so, it's not a "real" permission issue, it's a program or process on your computer that is giving the error.
The best solution that has worked for most people is to simply uninstall Internet Explorer enhanced security configuration.
Method 2 - Turn off anti-virus or firewall If you are having this issue in Windows XP or Windows Vista, then your problem is probably related to an actual permission issue.
Norton Internet 200X, Bitdefender, AVG anti-virus, Trend Micro 200X can all cause this problem. If you have any of these programs installed, make sure to disable them and test it you can run programs, open files, etc.
If so, then you'll have to either use a different program or find something on the Internet about to how to configure your software to not interact badly with Windows.
The same thing can also happen with an overly aggressive firewall. If you are running Comodo firewall or something similar (other than the basic Windows Firewall), then disable that also.
Method 3 - Unblock the file If neither of those two methods worked, the file may be blocked by Windows. Note that this is only for Windows Server 2003 and higher.
When you copy an EXE file from another computer to a Windows Server 2003 box, there is what is called a blocked property set on the file. This is due to the increased security on servers.
Right-click on the file and choose Properties. You'll see a button called Unblock at the bottom.
Wireless communication issues could be due to wireless signal quality, signal interference, firewall, etc. Make sure your printer is positioned where it receives excellent wireless signal strength (avoid physical obstructions whenever possible) and away from appliances which emit wireless signals (e.g. microwave ovens, cordless telephones, baby monitors, and other wireless electronics) that may cause interference. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
