Question about Sony Ericsson K750i Cellular Phone
Cell phone is dead while installing updates
While downloading latest updates from the SEUS website, the phone was getting downloads and suddenly message appeared as 'error downloading the updates' and the mobile failed to switch on. Again I tried to update the software and the message is 'No updates available' and after that 'the software is uptodate', but it is not getting switched on. Please find me a solution.
Installing phone software through update service failed
Posted on Aug 06, 2012
  • 790 Answers
While updating u should have a proper internet connection ... or else u ay lose the phone ...
Posted on Nov 28, 2007
I hav SE w705.when ever i download any theme the menu icons dont change so im lukin for a theme that will change my menu icon .pls help
You should need to unlock your phone and install some specific software to modify your phonev4ndre_5.jpg there is some programs and special firmwares to reflash your cell phone, but the procedure is very dangerous, do it at your own risk...
1. Download the SEUS (Sony Ericsson Update Service) program from the main SE page. (Navigate to your phone model and download "Update Service" program at the download section.
2. After downloading the SEUS (Sony Ericsson Update Service. I will write only SEUS in the rows below) you need to make your computer ready for the update process by installing USB flash drivers for your phone. These USB drivers are not the sandard ones and it's installation is a bit different comparing to the standard ones. So to install USB flash drivers (I hope you're using Windows XP) the procedure is the folowing:
- Turn off the phone;
- Remove the battery;
- Remove the Sim card;
- Place the battery in the phone again;
- While your phone is turned off connect it to your computer via the USB cable holding the C button on the phone pressed down all the time. (Tips: "Do not release the C button until you're prompted to do it" , "REMOVE the SIM card from the phone before starting the update process" , " Keep your phone turned off when connecting it to the computer holding the C button pressed down")
- Your computer will recognize the phone now as new hardware (USB Flash Device) and then you will need to install the USB Flash Drivers for your phone. Follow the Windows new hardware wizard. It will prompt you to insert the CD for your new hardware. The flash USB drivers are in the PC Suite CD you got when you bought the phone.
- After the Drivers setup is finished successfully, plug out the phone from the cable and restart your computer. Restarting is recommended, so do not try to start the update procedure without restart.
3. The next thing you have to do is to install the SEUS program you downloaded from the main SE website (the link above). It's setup is easy and it will install in a couple of minutes. After SEUS program is installed, restart the computer again.
4. Now you can start the update process for your phone. If everything is OK it should be like this:
- First I would like to recommend you to not start the update process if you have very slow or unstable internet connection, because the new software for the phone is downloded directly from the Internet and it does not have to be interrupted with anything;
- Quit your all running programs (This is recommended if you have antivirus or firewall software which blocks the network activity of untrusted applications. If you have one like this, give the SEUS program unlimited permision to access the web anytime it needs. Or the best, turn off that software.);
- Start the SEUS program you installed;
- Then you need to follow the instructions from the wizard;
- When asked, turn off the phone;
- Remove the SIM card'
- Connect it to the computer holding the C button (Tip: Release the C button only when you are prompted to do that. Releasing the C button earlier than it need to be will interrupt the update process so you can kill your phone. Some computers won't prompt for release the C button so you can release it when the updating procedure is started.);
- Then you will see an animated picture of some gray phone connected to computer via the USB cable. In this step you can release the C button and wait while the wizard is downloading the new software for your phone and installing it. You can see the status of the flashing procedure in the screen on that gray phone on the picture. Its display will start to fill with green from the bottom to the top of the screen;
- When done the updating procedure, click the update process you will be prompted to plug out your phone from the computer and close the wizard. With that, the update procedure is successfully completed;
5. Now you'll need to see the success of your work by Turning the phone on, but when you finish the update procedure do not remove the battery to insert the SIM card. Try to turn the phone on when you plug it off the computer. Keep the power on button pressed down for some time. It won't turn on fast as usual. If it does not turn on, remove the battery then. Insert the SIM card. Let the battery out for 2-3 minutes and try turning it on again. If the update procedure is made as it needs to be, the phone will surely turn on (but not fast as usual, but it is only for the first time.).
Dec 06, 2010 | Sony Ericsson Cell Phones
My Sony Ericsson G900 become DEAD after failed update use SEUS. What can I do now?
Hello, Olga.
Remove and reinsert the battery to see if it revives.
If not, and your PDA is still under warranty, return it to Sony for a replacement.
Hope this helps.
Mar 14, 2010 | Cell Phones
Sony ericsson m600i - screen response problem
When did you did firmware update? Use SEUS and get the latest (and final) update. It should work fine then. Had similar problem with my W960i.
Sep 26, 2009 | Sony Ericsson M600i Cellular Phone
W810i sony phone
it indecate that your phone is affected by a virous.you have better to send it to a service center.
Sep 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Its firmware is damaged and i want to reinstall it but it don,t recognize by the pc
The one and the only way to reinatall the firmware is throught the Mobile Repair shop, they write directly on the chip with the special hardware...
This is the only way if your mobile is not recognized by the PC
Enjoy! Rate this solution
RNJ VINOD KUMAR
Jul 14, 2009 | Sony Ericsson Walkman W810i Cellular Phone
I also hace the same peoblem,that my w810i is just flashing on and off...can i get any software from your site to fix it up by myself without taking it to the shop??
When I had the white screen problem, I was about to replace my W810i before I found out about the Sony Ericsson Update Service (SEUS). I used it to fix the firmware inside my phone, even though the phone seemed dead and my computer wouldn't recognize it. You can download the SEUS from Sony's website here:
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w810i?lc=en&cc=us
Jun 15, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Suddenly display went off N 95 normal version
it is a software glitch ,you should visit nokia website and download latest software , this fixed the problem since updating the phone has not crashed again , it is also caused in some instances by some of the applications games you have installed.
May 19, 2009 | Nokia N95 Cellular Phone
My sony ericson w810i wont switch on properlly it goes onto a blank orange screen 9walkman screen) but has no functions cant then do anything with the phone is this likely yo be the software ?
May 18, 2009 | Sony Ericsson Walkman W810i Cellular Phone
W810i flashes me a white screen then nothing
Apr 03, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Sony Ericsson K750i Cellular Phone Logo
119 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
