Question about Kenmore 95002 / 95004 Electric Kitchen Range
Front right element stays red hot at all settings and other times it works properly
    President:
  • 744 Answers
Hello, sounds like you have a bad infinate switch, your going to need to replace it before it lights up all the time...infinate switch is the knob that controls it...good luck!!! if you have any other questions please feel free to comment again.
Posted on Jul 13, 2009
The top right side and the right side of the get very hot when drying clothes
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 26, 2015 | Dryers
My Amana Tandem 7300 electric dryer will not stay
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 27, 2014 | Dryers
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
The right front burner will not get hot. It is only warm never hot. The burner doesn't turn bright red even when tuned up on high.
hello, try changing that front element(burner)if its easily removable to another side that is working normal. If the element is still dull not heating or glowing normal then replace the element, but if it does, then there is something wrong with the front right element switch or the receptacle.
Oct 30, 2010 | KitchenAid Kitchen Ranges
Water is staying too hot after elements were changed
Usually heaters are wired so that the upper element comes on alone and only after it has reached it's set temperature does the bottom element come on. If wired incorrectly both elements come on at the same time. Could cause extra hot water in top of heater. If the temperature sensors are not right up against the metal of the heater they will run hotter then you have set. Since the new elements are now more efficient than the old ones they could be making more heat at the same setting you had before so lower the setting.
Sep 20, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Are the heater coils supposed to stay bright red the entire cooking time when broiling?
You posted under a JGBP90 GAS Kitchen Range.
If you have an electric range, you should leave the door set to the part way open position (about 4 inches) when broiling, and the top (broil element) normally stays red hot the entire time then.
This should be a Fix-Ya for your problem.
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Turn front element on and back element comes on also
I ordered a new Cartridge, cause the back element burned out. Maybe it will fix the problem.
Dec 04, 2008 | Cooktops
Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
260 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
