Son has a window a/c, model no R0501 M which works in all respects except air coming out is not cooled
    Champion:
  • 233 Answers
Check and verify the compressor is on, also the cleanliness of the coils, the outside coil may look clean from the outside, and be totally clogged from the inside. You can remove the unit and take the top cover off and verify operation and clean it, (i assume that the unit is a small 5000 btu by the model number)
Posted on Jul 14, 2009
Automotive electric window repair
Probably a loose or corroded connection in the master window switch. Sometimes if a window is down when it is raining the switch will get wet and cause some corrosion on the contacts.
Jul 26, 2015 | 1999 Lexus RX 300
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
I have a Whirlpool Model ACQ158XPO wall/window air conditioner. Motor comes on but it does not cool. Any suggestions?
Its really tough to troubleshoot window units without pulling the cover off. If I was standing there looking at it without tools in my hand I would first make sure the fan/cool switch was in the fan high cool mode and that the thermostat was turned all the way to the coolest setting. Beyond that it needs to go in for repair. Wish I could be more help. Good luck.
Oct 05, 2014 | Whirlpool ACQ158XP Wall/Window Air...
Hotpoint 9328w isn't producing any hot air to dry the clothes
If its posssible for you chech to make sure you have 240v coming to the appliance , if so your probably looking at a element or thermostat issue.
Apr 16, 2013 | Dryers
We have a Jenn-Air electric slide in oven, model W131. It appears to work fine in all respects except that it doesn't come up to the set temp even though it tells you it has. Set at 350, it notifies...
if you changed the sensor most likely it will be the clock assy.it's not just a clock it also has a computer board built into it.you're missing a few letters off of the model number so when you call your parts store give them the full model number so they will sell you the right clock assy. i believe your board is around 150 dollars.if the elements are good and a new sensor all that's left is the board or clock assy. good luck with your stove.
May 23, 2011 | Jenn-Air SVE47100 Slide-In Electric...
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
My son took the old thermostat off the wall and didnt mark the wires. I have a new CT87K4446. The wires I have coming out of the wall are red green and white. On the new thermostat I have R W Y screw downs...
Usually when you have the Y terminal on the thermostat (that would be cooling terminal), there should be 4 screws to connect to. They would be R- to transformer, W- to furnace or heat, Y- to outdoor air conditioner and G- to furnace blower.
You might go to the furnace to see where these wires go, they should have the same terminals on the furnace except for cooling, it usually connects to the outdoor unit wire directly.
Oct 12, 2009 | Heating & Cooling
No cooling
May have burnt wire or bad capacitor to compressor.When running incool can you here the compressor running or is it maybe just the fan outside running?
Jan 08, 2008 | Fujitronic FH-797 Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
