Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
I am trying to set up the fax. I have a phone
I am trying to set up the fax. I have a phone cord from the first port to the wall outlet. I dial the number and it repeatedly says the line is busy and it is not. Is this a problem on my end or the other end?
  • danielle yancer
    danielle yancer May 11, 2010
    Do you have the printer connected to your pc?
  • 295 Answers
There should be a dedicated fax line to the printer. there should be no answering machine also. if ur using an dsl line,then u have to have a splitter on the wall outlet.fax line should be different from normal telephone line
Posted on Jul 28, 2009
Why is there no dial tone?
check cable
check modem
phone is working ok must be either of those or the fax settings. Also check owners manual
Jun 26, 2015 | Office Equipment & Supplies
Can not send outgoing faxes on brother mfc-8220.
There are a number of reasons why you may not be able to send a fax. Check your manual for troubleshooting tips. However here are some simple things to try.
1. Check to make sure the cord from the outlet in the wall to your all-in-one is plugged into the proper port. There are usually two ports that will accept your phone plugs on the back of machine. One goes to your phone or answering machine and the other one to the line that goes the outlet in the wall. It's easy to plug your cord into the wrong port. Try plugging your phone cord into the other port and see that works.
2. You may have a defective phone cord or the wrong type of cord. Most phone cords only have two conductors in the cord and others have four. Try replacing the phone cord with a known good phone cord and see if that helps.
Oct 11, 2013 | Brother MFC 8220 All-In-One Laser Printer
When I try to send a fax on my lexmark x4650 it has error no dial tone?
If you are getting "no dial tone" as an error on your fax machine, it means that you have the telephone cord plugged into the wrong port on it.
Turn the printer around so that you can see the back of it. If you look closely, there should be three ports to choose from in which you connect a telephone cord. Sometimes they put a little white plastic piece in the ports to keep them clean during shipping ect. If this is the case, go ahead and remove them now.
If you look closely at each port , you might notice that they have text or pictures right above or below them to tell you which one to use. let me explain; if you have one telephone line and wish to use it for both fax and voice calls - you will need more than one port. That's why they mark them.
One of the ports should say "line" or have a picture with a funny little symbol on it. This is the port that you would use if you want to fax someone using your printer. You plug your phone cord into this port on your printer.
One of the ports should say "phone" or have a picture of a telephone by it. This port is used when you want to share a single phone line with both your fax machine and telephone used for making voice calls. To split your line between both fax and phone, you plug your phone cord from the wall into the port marked "line" and take a second phone cord and plug it into the port on your printer marked "phone" and the other end of that line goes into your telephone (voice line).
The last port should say "line 2" or similar and usually has no picture next to it. This is an additonal port to share with a second phone line.
To correct your problem of "no dial tone", plug your phone cord into the socket on the wall and put the other end into the port on the printer that says "line". Now lets test the connection.
Put a piece of paper into your printer, press the fax button and dial any phone number using 1 and then the area code followed by the phone number and press 'start" or "ok" to begin the fax. If you have chosen the right port to connect your telephone cord, you will hear a dial tone first, and then dialing of the numbers you chose. If you cannot hear a dial tone before your numbers begin, then you have not chosen the right port. If this is the case, remove the phone cord from the port you have chosen and try another until you do hear the dial tone.
NOTE:
Do not try to go from your phone jack into your telephone and then use a second port on your telephone to connect a second phone cord that is plugged into your printer/fax. A second phone port on your telephone is most likely for a second phone line to use for voice calls. The majority of phones for residential use do not have a built in splitter that works like a fax/printer does. If you try to use a second port on your phone to split to your fax machine, it usually will not work. Follow the instructions as listed above to re-route your line and correct the problem.
MAGIC JACK USERS:
While magic jack is great for making free long distance calls, it is not suggested for use with a fax machine. if your trying to use your magic jack phone line to fax it usually does not work.
Jul 16, 2011 | Lexmark X4270 All-In-One InkJet Printer
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
We cannot dial out when sending a fax. You can hear the line open but no dialing tone. Any ideas?
  1. Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
  2. Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
  3. Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
  4. Try sending and receiving faxes on a different fax line.
  5. Try using a different telephone cord.
  6. Have the phone company test your line for static or noise problems.
  7. Turn Error Correction Mode (ECM) off, if you encounter the same error repeatedly.
Regards
Riztech
Nov 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Fax wont' go through. Plugged phone jack into phone line and when I try to fax it doesn't connect. Any suggestions? Thanks
Can you receive any faxes. Run a Fax Test from the Tools menu. Is the problem with only one fax receipient? (Check the phone number and make sure they are set to receive. I have dealt with one fax receipient where the call-waiting service caught the fax call.)
Does the Fax see a dial tone? If there is no dial tone, use a single line phone (corded) to listen for a dial tone at that jack. If there is no dial tone, check the incoming service for a dial tone. (If you have no dial tone at all, contact your service provider.) Try a new phone cable (2-wire RJ-11) Try calling the number from another phone line with the single line phone attached. If the phone doesn't ring with a new cable, check your wiring and then contact your provider. Is the signal analog or digital (the all-in-one is designed for digital)?
Go back through the fax settings and set it as directed in Step 2 here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458259&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3643612 . You need the fax error reporting setting.
Disconnect any items that are plugged into the 2-Ext port.
Try reinitializing the unit. Unplug the power cord with the unit on. Make sure that the phone cord is fully seated in the 1-Line port. Then reconnect the power cord.
Try resetting the all-in-one, this may require 2 people. With the printer on, unplug the power cord and wait at least 20 seconds. Press and hold # and 3 while plugging in the power cord. Release the buttons after the unit starts up.
If none of these steps help the unit may need service.
Jun 27, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Our HP Office Jet 4255 all in one suddenly won't receive faxes for some reason. It has been working fine up until now. We can send faxes, but for some reason the phone just keeps ringing and won't...
CHECK THE TELEPHONE NO.
Verify that you are dialing the number correctly. (i know its funny to ask)
Verify that you are dialing the number correctly. You must dial all of the numbers required to make a phone call from the same line. This includes numbers that must be dialed to access an outside line or to access long distance services.
TRY DIALING FROM THE FRONT PANEL
manually dial the number from the front panel of the fax.
If you have been using a speed dial or are faxing from the computer, print the page to be faxed and manually dial the number from the front panel of the fax. If the fax can be sent when dialed from the front panel, recreate the speed dial setting and insert some pauses.
Check the connections
Check the TELEPHONE LINE
Check LIU
Remove the SPLITTER
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Jan 05, 2010 | HP OfficeJet 4255 All-In-One InkJet...
Faxing error
Plug a regular phone into the wall outlet and listen for a dial tone.
Make sure the phone cord is plugged into the LINE port of the fax machine.
Oct 14, 2008 | Canon Office Equipment & Supplies
Fax
To test your fax setup
1 Press Setup.
2 Press 6, and then press 5.
This displays the Tools menu and then selects Run Fax Test.
The HP all-in-one displays the status of the test on the color graphics display and prints a report.
3 Review the report.
– If the test passes and you are still having problems faxing, check the fax
settings listed in the report to verify the settings are correct. A blank or
incorrect fax setting can cause faxing problems.
– If the test fails, review the report for information on how to fix any problems
found. For more information, you can also see the next section, The fax test
failed.
4 Press OK to return to the Setup Menu.
Make sure you used the phone cord supplied in the box with your HP all-in-one
to connect to the telephone wall jack. One end of this special 2-wire phone
cord should be connected to the port labeled "1-LINE" on the back of your
HP all-in-one and the other end to your telephone wall jack
This special 2-wire cord is different from the more common 4-wire phone cords
you might already have in your home or office. Check the end of the cord and
compare it to the two types of cords shown below.
If you used the 4-wire phone cord, disconnect it, find the supplied 2-wire cord,
and then connect the 2-wire cord to the port labeled "1-LINE" on the back of
your HP all-in-one. For more information on connecting this phone cord and
setting up your HP all-in-one for faxing, see Fax setup.
information see The phone cord that came with my HP all-in-one is not long
enough.
● Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP all-in-one and check for a dial tone. If you do not
hear a dial tone, contact your telephone company and have them check the
line.
● Other equipment, which uses the same phone line as the HP all-in-one, might
be in use. For example, you cannot use your HP all-in-one for faxing if an
extension phone is off hook, or if you are using your PC modem to send an email
or access the Internet.
● The phone line connection might be noisy. Phone lines with poor sound quality
(noise) can cause faxing problems. Check the sound quality of the phone line
by plugging a phone into the telephone wall jack and listening for static or
other noise. If you hear noise, turn Error Correction Mode (ECM) off and try
faxing again. For information, see Use error correction mode. If the problem
persists, contact your telephone company.
● If you are using a digital subscriber line (DSL) service, make sure that you
have a DSL filter connected or you will not be able to fax successfully. The
DSL filter removes the digital signal and allows your HP all-in-one to
communicate properly with the phone line. Obtain a DSL filter from your DSL
provider. If you already have a DSL filter, make sure it is connected correctly.
Make sure your HP all-in-one is not connected to a telephone wall jack that is
set up for digital phones. To check if your phone line is digital, connect a
regular analog phone to the line and listen for a dial tone. If you do not hear a
normal sounding dial tone, it might be a phone line set up for digital phones.
● If you are using either a private branch exchange (PBX) or an integrated
services digital network (ISDN) converter/terminal adapter, make sure the
HP all-in-one is connected to the port that is designated for fax and phone
use. Also, make sure that the terminal adapter is set to the correct switch type
for your country/region, if possible.
Note that some ISDN systems allow you to configure the ports for specific
phone equipment. For example, you might have assigned one port for
telephone and Group 3 fax and another port for multiple purposes. If you
continue to have problems when connected to the fax/phone port, try using the
port designated for multiple purposes; it might be labeled "multi-combi" or
something similar. For information on setting up your HP all-in-one with a PBX
phone system or ISDN line
you may also refer to the manual for this unit here
if you go there please refer to page 82 of the manual or chapter 10
Aug 02, 2008 | HP Photosmart 2710 All-In-One InkJet...
Can I reconnect to pasha
Plug a regular phone into the wall outlet and listen for a dial tone,
May 12, 2008 | HP 640 Inkjet Fax Machine
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
61 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
