Question about Palm Treo 680 Smartphone
LCD/digitizer replacement My wife dropped her phone and the digitizer was cracked. The phone would still work as a phone if i called her but she could not see anything on the screen. I lit up but it looked like a crack with ink spots on the screen. I bought and replaced the LCD/digitizer touch screen. After replacing, the phone comes on and everything is seams to be working properly except the touch screen features. I've done a hard and soft reset but that did not correct the problem. Any suggestions? Please help!
  • 143 Answers
Unfortunately, when it comes to touch-screens, it's much more difficult to fix.
The reason being that the screen is placed in the chassis of the device - with precision, so that none of the parts in the device or the chassis/cover of the device itself is applying any pressure to any point on the screen.
If there is any point on the screen which is being pressed by the cover of the phone or any part of the phone such as a wire or PC board, the screen will be reading TWO inputs whenever you push a button on the screen. Most touch screens will lock up if it detects two points of pressure...or it will pick one input and run with THAT one. (Hard to say if it chooses the first or the second input.)
I have a Dell handheld PDA that I can't put the cover back on as it works sporadically when I tighten the screws back down. I know the general region where the pressure is being applied, but no matter what I have done, it just won't work. (It's not worth my time, so I haven't really continued working on it for some time now.)
Sometimes when I flex or bend the chassis of the PDA and I use the stylus on the screen, it'll work for a while. But then you grip it in a certain way and it starts going crazy all over again. When I bend the chassis by twisting it a bit, it releives the point of pressure and I'm able to use it normally for a while. Sometimes I tap the sides of the device to knock the screen back into place. (Although that can be harsh on the device.)
Quite honestly? I would take that phone to a service center and either have them service it or replace it. (But you most likely voided any warranty you still had when you opened it; if any.)
Not much that can be said for it unless we could actually physically inspect it. But this is the internet. :P
Try jarring the screen or inspecting the bottom side of the front cover to see if there is any point that is touching the screen when you secure it. Try removing the screws in certain, contained areas in a slow manner to see if releiving pressure in those areas might show you where there may be something touching the screen. Take it from there. Might consider using a file to file down the area that is touching the screen.
First and foremost, though... Just check to see if the screen is centered right where it's supposed to be.
Good luck with that. I hate touch screen repairs. :P
Posted on Nov 16, 2007
Lg reset
Sounds like the LCD digitizer which either broke inside OR became disconnected. If the impact was not enough to sustain a screen crack, and you have warranty with either LG or through your carrier, you can get LG to fix it free if there is no physical damage, cracked screen, or water damage, with your carrier, it would be the easy, just tell them the screen isn't broken, the phone is intact but the screen is blank. That is a hardware failure... they are supposed to be able to withstand some drops so it really depends on how much physical damage there is.
A digitizer LCD is not expensive and there are ways to change them fairly simple since the screen isn't cracked, you go through most LG phones via the back, remove the camera, remove a black cover that holds the sim and or memory card, BE CAREFUL and please look at youtube to see a complete disassembly of your particular LG phone.
Jul 16, 2014 | LG Cell Phones
I dropped my Phone when it was open and the inside screen cracked. The rest of the phone works fine. Can I get the inside screen repaired?
yes you can. There is a company in denver , co that does repairs called wireless image. You can contact a local repair center or any cell phone place that does repairs will do it for you.
Oct 21, 2010 | LG enV Touch VX11000 Cell Phone
My bold has a white screen with a couple black lines going vertically and a black circle/blob in the top right. The phone was never dropped and has no crack in the screen. Please try and help restore to...
You don't have to drop your phone to crack / break the screen. This problem is almost certainly caused by a crack screen. This can be easily repaired by taking your phone to the local repair shop and getting the LCD replaced.
Depending on where you live and who you know you can get this done for $50 - $100 in North America.
Oct 12, 2010 | RIM BlackBerry Bold 9700 Smartphone
Samsung tocco 480 screen is cracked/broken
The screen should keep working with the LCD cracked. i.e you should be able to receive calls.
You can find replacement LCD screens for Samsung F480 in this link:
I hope it helps.
Ignacio del Olmo
May 26, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
I dropped my iphone and now the unlock slide doesnt work
It looks like you need a new LCD/digitizer which you canreplace yourself. Here's a guide on how to disassemble an iPhone. Maybe a tech savy friend can do it for you. If you want to have somebody else do it for you there are third party iPhone Repair Services.
Mar 18, 2009 | BoxWave Corporation Apple iPhone 2G...
You can replace the lcd screen and digitizer.
Its about $40 US on ebay. Try searching treo 750wx screen/digitizer/touch screen, etc. Also i tried searching treo 750wx but it didn't work, I suspect the 750 to be the same as the wx, but you might wanna make sure with the seller incase (Ask seller a question link is on the listing, or click their username and go to their profile and click on contact)
Feb 27, 2009 | Palm Cell Phones
Lcd screen cracked
Did you drop the camera? is it under warranty still? call your manufacturer for servicers/ experts on area that can replace the cameras LCD screen. If within warranty they might replace it if LCD is broken out of the box.
Hope this helps
Sep 27, 2008 | Cameras
Cell phone dysfunction
I am not sure on your phone but the screen on my wife's u740 turned white right after I dropped it. I had to get a new phone because I didn't look into replacing the lcd first. That was the discription of my problem from verizon was a pressure crack in the LCD. I hope that helps.
Nov 25, 2007 | Samsung SCH-u740 Cellular Phone
LCD display cracked
You can replace the lcd screen although you do need to be careful. You camera has a flash capacitor that contains 300 volts and if you short it out you can easily fry the camera circuitry. You can check on ebay for an lcd or call fuji usa. I will warn you though their parts department isn't the most helpful.
Nov 13, 2007 | Fuji FinePix A303 Digital Camera
My inside display is not working. - Motorola Razr V3
you need to take the phone to a mobile service center and have them replaced the LCD for you.
Nov 01, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Palm Treo 680 Smartphone Logo
2,859 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
