Question about Olympus Stylus 710 Digital Camera
Write Protect Erro
I have an olympus fe-370. I keep getting the write protected image and even after i format the sim card, once i plug my camera to my PC the problem starts again. Can anyone help me with this problem?
  • 37 Answers
On SD cards there is a small lock that prevents writing to the cards. Check that.
If you are sure there is nothing on the card, remove it from the camera and insert into a card reader attached to your computer and see if anything is there.
You can try to delete everything on the card from the computer then reinstall it in the camera. MAKE SURE YOU FORMAT THE CARD IN YOUR CAMERA BEFORE TAKING ANY PHOTOS.
Posted on Jul 13, 2009
  • Larz Jul 13, 2009
When i switch on my digital camera write protect message is displayed on it , my camera is olympus fe-190
If your camera uses a SD memory card then the write protect switch maybe on.
SD and Micro SD memory cards has a smallslide switch on the edge of the card, which write protects data on the memorycard. Slide the switch from the READ position tothe WRITE position, which is furthest away from the contacts.
May 06, 2012 | Olympus FE-190 Digital Camera
How to fix write protect from my olympus FE 190 model
Good day,
This tip will explain how to remove the write protect from your SD Card.
This is a easy fix and won't take a minute.
First remove your SD Card from your device. You will see on the side of the SD Card that there is a small switch. If your SD Card complains about being write protected simply put the switch in the opposite position. Some of the SD Cards even have the word LOCK on near the switch indicating the direction the switch must be to LOCK the card.
Once the switch is changed you can put the SD Card back into your device and the problem of write protection would be solved.
Please feel free to let me know if this tip was able to help you!
Regards
Apr 05, 2011 | Olympus FE-190 Digital Camera
My camera wont take pictures when i have my memory card in it it says write protect. but when i take the memory card out it will????
When you remove the card, the camera is using its built-in internal memory which is very small and won't hold many pictures. Does your card have a slide switch on the side? If so, it should be in the unlocked position.
Nov 28, 2010 | Olympus FE-370 Digital Camera
How do I delete all the pictures at once on my Olympus FE-370?
Go into the menu and find "format"...follow the on-screen instructions.
Oct 14, 2010 | Olympus FE-370 Digital Camera
How do you upload pictures from an olympus fe-370 camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
Jun 19, 2010 | Olympus FE-370 Digital Camera
Memory card showing 'no image' after trying to upload
Sounds like you didn't use the "safely remove hardware" function when you disconnected the USB cable. This can corrupt the card and even the camera. You could try using a separate card reader to download the pics from the card. If that works, and the pics are safely downloaded, then you should format the card in the camera to erase and optimize it. If it doesn't work, take the card to a Walmart that has a Kodak Picture Kiosk and it should be able to read your card. You can print the pics or even make a cd of them. Then, format the card in the camera.
Apr 01, 2010 | Olympus FE-370 Digital Camera
Olympus fe 370 xd card 2gb formatted memory
As long as the xD card was not formatted it is possible to recover the images that were accidently erased,lost or corrupted. You can go to the following website link and download an image recovery software program that is free of charge. http://www.z-a-recovery.com/ You want to download a program called Zero Assumption Recovery. It is a very simple program to use and many people have had much success in recovering lost images. Data recovery is a booming industry, and many appropriate services and software can be found by searching regional phone and business directories or the Internet for terms such as "image recovery" or "data recovery".
Jun 10, 2009 | Olympus FE-170 Digital Camera
Write protect
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - Press Ok- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Dec 28, 2008 | Olympus FE-230 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Olympus Stylus 710 Digital Camera Logo
111 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
