Question about HandHeld Entertainment Audio Players & Recorders
Cordless mic not working
We have an older cordless radio shack mic and we can hear it come on thru the pa head, but not when we talk into it. Do you know anything we may can check on it? Don't have the means to buy a new one, and hate it because it appears to be in really good shape, receiver and all. Have replaced batteries, and tried all 8 channels on the receiver. We used it regularly about 5 years ago so I know it was fine, and stored properly.
Thank you for your help.Tonya Everett
Radio Shack professional cordless mic 32-1230A
    Master:
  • HandHeld Ent... Master
  • 923 Answers
How old is it? The problem with older electronic products is that capacitors suffer what is commonly called "ESR failure." ESR stands for equivalent series resistance. Basically, they simply dry out over time, or leak. New capacitors usually are very INexpensive (a few cents apiece), but most people know next to nothing about them, nor how to troubleshoot them in-circuit. On the other hand, some of us do know how, but labor is expensive. The best solution, is to simply replace ALL the capacitors in such units, which will usually cost less than $5.00 for the whole lot, and either replace them yourself, or have a friend or hobbyist replace them for you. But soldering technique is important! Soldering is not for beginners, nor for wimps!
Posted on May 12, 2017
2 Suggested Answers
  • 11800 Answers
SOURCE: I have a Radio Shack
Yes, it can be repaired: the wires must be resoldered and the plastic base patched together with a hot glue gun. But it will be fragile from now on - the repaired base will not hold too much mechanical shocks. All it will cost is the labor, about 2 hours - no parts are available for it.
Posted on Dec 06, 2010
Can I buy a cordless microphone for the 5' bony tony skeleton, item # 70467?
Wireless microphone would require a large rework of the item. It can be done with a wireless system from Radio Shack. Other wireless microphones are quite expensive.
Sep 26, 2016 | Lands Phones
NOT RECEVING OR TRANSMITING
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
Jan 04, 2013 | Radio Communications
Microphone problem
I might be wrong, but a wiring problem sounds like the culprit here.
Where the mic connects to the PCB, inside the radio, something has come adrift, the fact that your keying is getting through means something is loose, open it up and have a good look at the connections, if you find the culprit, fix it with solder, but be very sparing and careful, you don' t want solder all over the area, else you'l stuff up the mic input completely.
I hope I'm right, and I hope this helps you fix it.
Cheers,
Peter
Aug 15, 2012 | Uniden PC68XL - CB radio - 40-channel -...
I only use the pa function.it doesn't always work.mic prob?when i switch to cb-no prob.
What type of PA speaker are you using? what OHM? and wattage.. A cb pa can only supply MAX 5watts into a pa speaker. It may be too big of speaker or bad speaker? if it works on cb.. wrong OHMS can make problems too..
Nov 15, 2011 | Radio Shack TRC-447 CB Radio
This is something new to me, what do I set all the buttons and knobs to talk on channel 19,hi-lo band,10khz on or off ,pa-fm-am,e/a-f/b-g/c-h/d, e-tone thanks for any help anyone can give me.
Radio On Volume comfortable Listening level Squelch Open (Hearing Noise) Mic Gain Up unless told by receiving station to reduce it. 10 Khz Off pa-fm-am set to Am e-Tone to off I believe this model has CB on Band C which is switch down on Low and C position you will know when you hear truckers on 19 which band is CB
Aug 06, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
When pa is on all i get is a shrill noise when i key the mike to talk what is the problem
TURN DOWN THE VOLUME ! ! ! You are getting feedback thru the mic because the speaker is too close to the mic.
Nov 20, 2009 | Cobra 19 DX III 40-Channels Base CB Radio
I have a hannspree comp monitor and an emachines media center CPU. My sound comes thru my comp screen speakers. I am trying to configure a radio shack multimedia headset so i can game and also use it...
I solved the issue last nite w/online chat w/rulds2008.
Had to unplug the regular headset from the comp, then use the very pink plug on the Radio Shack Multi Media Headset and plug that into there.
Then the other odd sorta pinkish/fushia colored plug goes into the mic spot.
Aug 16, 2009 | Computers & Internet
My mic doesn't work; callers can't hear me
I don't have the answer but have the same problem. Uniden tech support had me disconnect power, etc. to no avail. Next solution was "replace the unit". I'm looking for a two-line phone with no answering device - use voice mail. Any ideas?
Mar 14, 2009 | Uniden TCX905 Cordless Accessory Handset...
Problem with TRC-503 Radio Shack CB
Does this radio have a pa/cb switch and if so is it on pa?
Feb 17, 2009 | Radio Shack TRC-503 CB Radio
Cobra 29 wx st
IF YOU CAN RECIEVE THAT IS A VERY GOOD SIGN THAT YOUR SWR MATCH IS OFF....I DONT KNOW IF YOU MATCHED UP YOUR RADIO WITH YOUR ANT.IF NOT YOU CAN BUY A CHEAP SWR METER @ RADIO SHACK...CHECK THAT YOUR COAX CABLE IS OK TRY TO REPLACE THE COAX......GOOD LUCK
Feb 14, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Top HandHeld Entertainment Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a HandHeld Entertainment Audio Player and Recorder Expert? Answer questions, earn points and help others
