Question about Garden
I need to replace my Traction/Hydro Drive belt. I'd like to keep unnecessary tear-down to a minimum. I note that the engine's belt loop straddles the steering and seems to require the electro-clutch for the deck belt be disconnected. Please advise. Toro Wheel Horse Lawn Tractor 269H [Model 72102]
Peuhayd
  • 11 Answers
SOURCE: removing tractor deck to change belt and blades?
if i am thinking of the right model you may be able to get away with first taking off the blade, then to remove the deck should be a number of bolts under the chassis and on top of the deck where it meets the frame... you can get your parts here if your having trouble finding them
 http://www.ordertree.com/modelinfo/MTD/13A1674G401-%281997%29/62.13A1674G401-%281997%29.1.1.1.html
Posted on Sep 06, 2008
SOURCE: why does the deck belt keep breaking on Poulan
its possible the belt may not be on the correct pullies. check the diagram and make sure it is routed correctly.the guy i bought my used mower from had same problem. i corrected belt route and have not broke a belt in the two years i've had it
Posted on Apr 13, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 61 Answers
SOURCE: Roper 16 hp Lawn Tractor: belt replacement
you need to remove the mower deck there you will see the pullys.
Posted on Sep 06, 2009
What size drive belt fits John Deer L110 ?
The youtube video shows you how to replace it.
This webpage also has detailed instructions:
https://jdagccc.custhelp.com/app/answers/detail/a_id/486/~/transmission-drive-belt-replacement---100-series-hydro-42-in.
This should be the replacement belt you are after. Please confirm before purchasing. http://www.greenpartstore.com/John-Deere-Traction-Drive-Belt-and-Idler-Kit-GX20006KIT1.html
Nov 16, 2016 | John Deere L100 Series
I need to know how to install drive belt on cub cadet that has hydro drive with diagram
That will depend on the model of your mower. Generally you have to remove the deck and deck belts. The drive belt usually goes from the engine pulley to the transaxle pulley. There may be a tensioner pulley as well that keeps the belt tight.
Jul 11, 2016 | Cub Cadet Garden
Z225 keeps throwing off drive belt, every thing is correct. if it is hydro, how do I know which side, both seam fine, except right side feels more stiff
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jun 01, 2016 | John Deere EZtrak Z225 Zero-Turn Riding...
Why the traction belt keeps jumping off the pump pulley
If it is an old belt, replace it. Also make sure all pulleys are tight and belt is in all of the belt guides.
May 20, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
1997 Jeep cherokee larado squeals replaced the drive belt a few times and it keeps tearing
Inspect the belt tensioner for the following conditions:
Noise
  • If the belt squeals, the tensioner force may be insufficient. Check the belt length gauge, if the length is correct, replace the tensioner.
  • If the tensioner clatters or rattles during engine operation, there may be internal interference or wear. Replace the tensioner.
  • If the belt chirps, you may have a worn pulley or tensioner or cracks in the tensioner bas or arm. Check the mounting bolts, if they are okay, replace the tensioner.
Sticking or Seized Tensioner or Idler
  • If the tensioner does not operate smoothly or doesn't move, you may have: internal thrust surface damage/wear, internal damage/wear, or a broken spring, replace the tensioner.
Appearance
  • Inspect the tensioner arm for cracks or other damage. If the tensioner is broken, it should be replaced.
  • Look for excessive tensioner movement at idle, which can indicate internal wear, an out-of-round pulley or loose mounting bolts. Check the mounting bolts, it they are in good condition, replace the tensioner.
  • Make sure the tensioner is not tilted or misaligned. Also make sure a gap exists between the tensioner arm and base. If you notice a problem, check the mounting surface, it the surface is okay, replace the tensioner.
Belt Tracking
  • If the belt does not track properly on the pulley tracking surface, you'll need to troubleshoot the problem. Check the mounting bolts and the system alignment. Then, make sure the correct belt is being used for the vehicle. If all of these things are intact, replace the tensioner.
Belt Length Indicator
  • A belt length indicator is built into each tensioner.
  • The gauge identifies the effective operating range of the tensioner.
  • It consists of a pointer and either two or three length marks.
    • On a three-mark gauge minimum belt length, maximum belt length and ideal belt length are indicated.
    • On a two-mark gauge only minimum belt length and maximum belt length are indicated.
    • Ideal belt length on a two-mark gauge is generally half way between the minimum and the maximum.
  • When a belt wears and stretches with age the tensioner will move towards the maximum belt length to maintain proper tension.
  • As the pointer nears the maximum length mark, replace the belt.
May 04, 2012 | 1996 Jeep Grand Cherokee
JD mower L110, hydro drive. Reverse power is low.
i have the same thing a tractor shop told me thats ok they are slowed dowm for saftey
Nov 01, 2009 | Garden
Drive belt problem
ck var speed pulley for movement on middle part
of pulley
Jul 29, 2009 | Garden
826LE Power Max Snowthrower_ Drive belt keeps coming off
part # 94-8812 is traction belt 106-4498 auger belt
There is a service bulltin on this I have not seen this yet, Ill paste it for you to look at .
this was issued dec 22-2003 you would think that it would have shown up as a problem by now.
UNITS AFFECTED: Model Number(s): Serial Number(s):
38620 240000001-240999999
38621 (Int'l.) 240000001-240999999
38632 240000001-240999999
38635 (Int'l.) 240000001-240999999
38642 240000001-240999999
38645 (Int'l.) 240000001-240999999
38652 240000001-240999999
SUBJECT: Traction belt jumps off the pulley.
SITUATION: Incorrect pulley alignment causes the traction belt to jump off, usually when the drive is disengaged or as a hill is crested.
CORRECTION:
1. Remove the belt cover, engine belt guide and the bolt securing the crankshaft pulley.
2. Remove the auger brake assembly.
3. Remove the crankshaft pulley and the auger belt.
4. On the left side of the machine, remove the hair pin cotter from the speed control link and slide the link out of the pulley pivot assembly. The traction belt can now be removed.
5. Shorten the pulley half nearest the engine (PN 106-7334) shown in Fig 1. Grind or machine 1/8” (.125”/3.2mm). from the hub end of the pulley. The new finished length of the pulley half should be 1.07” (2.7cm).
6. Chamfer the bore to ensure the pulley fully contacts the shoulder on the crankshaft. You can send the pulley to an outside machine shop if you do not feel that you can modify the pulley in house.
7. Reinstall the pulley with a new traction belt.
A. Chamfer edge after grinding/machining.
B. Remove 1/8”.
C. Masking tape used as a reference line.
8. With the engine off, engage both the traction and auger levers and inspect the alignment of both the auger and traction belt idler pulleys (Fig. 2). Since we have moved the crankshaft pulley it may be necessary to bend the idler arms slightly to center the belts. Adjust as needed.
9. Install the engine belt guide and test operate.
10. Install the belt covers.
PARTS: P/N 94-8812 Traction Belt
Feb 04, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Garden Logo
271 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
