Question about Acer AL1916W 19" LCD Monitor
The screen of the Acer AL1916W no sign of life
Bogsnoy had suggested checking the F200 SMT fuse and it is bad on my monitor. Can you tell me what the current rating is for that fuse?
5amp 250 volt
Posted on Aug 18, 2009
My acer montior turns on fine, screen appears fine for a couple seconds, then blinks pinkish in colour and shuts off. This is a desktop computer monitor.
Pinkish glow can be sign of bad lamps, which will not be worth fixing.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 23, 2011 | Acer AL1916W 19" LCD Monitor
Acer al1916w a lcd monitor power up and shut down
It probably has porblem in the power supply/inverter board, you need to look for bad caps with domed tops, bad MOSFET in the inverter circuits, inverter transformer
See pictures here: http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1916W/
Feb 04, 2011 | Acer AL1916W 19" LCD Monitor
I got an Acer AL1916W 19" when I turn it on, It
Inspect the caps first.
Dec 16, 2010 | Acer AL1916W 19" LCD Monitor
MY SCREEN IS ALL BLACK. I DON'T KNOW HOW I MADE IT THAT WAY YOU SEE I FELL ASLEEP AT THE KEYBOARD AND I DON'T KNOW HOW I DID IT. IS THERE A WAY TO RESET THE MONITOR TO FACTOR SPECS? MY MONITOR IS AN ACER...
I would try this monitor with another PC to make sure it is not PC problem because we do not want to open up the monitor unless we have too.
Post back what you find.
If it is monitor, then read on:
Dec 07, 2010 | Acer AL1916W 19" LCD Monitor
Monitor ACER Model AL1916W Problem
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 16, 2010 | Acer AL1916W 19" LCD Monitor
I have a ACER Monitor Monitor AL1916W. When I turn on the light switch come on, but the screen remain dark.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
It suggest checking the F200SMT fuse, but we do not know where it is located
The F200 fuse is located on the bottom of the power supply board the SMT part of the number means the fuse is a surface mount which is very ver small. If you go to our web site at: www.ccl-la.com/monitor_repair.htm we have a step by step guide for this monitor. More than likely you will also have to replace the 2 MOSFETs and 2 capacitors as shown in the repair guide. Your power supply should be model DAC19M005. Email me if you have any questions.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 18, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W no sign of life.
If Power LED lits up and then turns to orange (standby mode) but no display, pls check SMT fuse (F200), replace the caps and replace 40T03GP power mosfet N-channel enhancement mode. Good luck
Apr 26, 2009 | Acer AL1916W 19" LCD Monitor
Monitor just stopped working, screen is white.
The totally white screen and no On Screen Display / Menu indicates your monitor is definitely faulty. Unfortunately the only solution is to have the monitor repaired, or buy a new monitor. If the monitor is still under warranty, the manufacturer should replace or repair it. Sorry to be the bearer of bad news :(
If you know someone that is technically experienced and is willing to try, replacing the logic board is fairly simple assuming you can find an exact replacement. I suggest searching google for AL1916W video board or logic board, you might find an electronics store that carries the part, or you might find one on eBay.
Jun 10, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
254 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
