SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
SOURCE: Whirlpool Cabrio Dryer 3 months old
"AF" is a restricted air flow condition. You say you've only had your dryer for 3 months, but have you ever cleaned the ducting? You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
SOURCE: Dryer words (AF) what does this means?
Low air flow. Means that your vent is blocked or crushed and check your lint trap also
SOURCE: AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
SOURCE: My dryer has the error code AF. what does that
Air Flow problem, check your lint filter and venting.
I have this problem please say the easy way
I have problem on my unimac dryer its appear on the screen airflow switch 2 error??.?
