Question about Sony Bravia EX440 42-inch KDL42EX440 1080p LCD HDTV
Kdl42ex440 dead hi i have a kdl 42 ex 440 and when i turn it on the red light goes on and the the backlight goes on for one sec and then there's a poping sound from the speakers and the tv shuts off and no blinking light. all voltages in the power supply are good. 3.3v & 12v. can you please help me
SOURCE:
SOURCE: Sony Wega Blinking Standby Light
No... we got it to come back on and now we havent tuned it off since... we just leave it on 24 hours a day!
Posted on Jan 06, 2008
  • 7 Answers
SOURCE: picture and sound cuts off ,greem stb light keeps blinking
How many blinks do you get? Depending on the amount of blinks you can figure out what the issue is.
If it blinks 6 times you can get the fix at
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
They have other fixes for E60A20
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70&keyword2=electronics
Posted on Jun 12, 2008
mistersony
  • 320 Answers
SOURCE: 42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Posted on Oct 19, 2008
  • 3 Answers
SOURCE: TV Goes to Stand-by mode
I don't have a solution, but I have the exact same problem
Posted on Sep 08, 2009
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Sony KDL42ex440 q6502,q6503 part number
The identifiers on the Sony transistors are proprietary part numbers so only Sony can identify equivalent parts, if any.
Apr 28, 2014 | Sony Bravia EX440 42-inch KDL42EX440 1080p...
Black screen , red standby light flashing 4x repeatedly, unplug it and the green light comes on momentarily then resorts to 4 red flashing lighrts again. Sony KDL-40V2500 approx. 4yrs old. HDMI cables are...
4 blinks indicated of backlight malfunction. The unit shutsdown to avoid overload to the inverter board.
Check the backlights, busted backlight has a physical indication of fault like blackened end, crack end. You must replaced the busted one and your unit will back to normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 16, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have the Bravia 40" KDL 40V3000. When I turn the TV on the panel powers up then the TV goes to standby and I get 13 flashes from the standby light. Reading on one of your other posts, I went ahead and...
Power supply board is dead 90% of the times.When the power turn on LED power light indication flashes.5% might be the Tuner board,that the board taking in the incomming broscasting cable plug into this board.5% might have both death boards,power supply board and the Tuner board.Problems,u have never indication LCD inverter board,backlight problems.U shouldn't have replaced the LCD inverter backlight board,bacause backlight are dead,have flashes of picture few sec.than dies,still have hear sound.
Aug 05, 2010 | Sony BRAVIA KDL-40V3000 Television
Tv turns on has sound
Have flashes of picture about 30 sec, or so?Than the 2 long LCD inverter boards are dead,have backlight make no difference.Tries to reset the tv back to factory setting by,unplug,replug the tv and cable box back about an hour later,let the tv Tuner board to reset it self,the cable box upgrade it softwares.After this,u still have the same problems,than the Tuner board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy the 2 long refurbishes LCD inverter boards or the Tuner board for the replacement.
Jun 24, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
No picture, red light flashing
Power supply board is dead.Replaced the power supply board well solved this problems.
Feb 17, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
42"doesn't turn on
your power supply board is going out.
Dec 06, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Four blinking red lights.
Either on of the backlight inverter boards is bad or a backlight has failed inside the panel.
Oct 11, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia EX440 42-inch KDL42EX440 1080p LCD HDTV Logo
514 people viewed this question
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
