Question about Printers & Copiers
Error Message F-26-3
My copier keep jaming and giving me the error message F-26-3.
The copier is F-26-3
  • 42 Answers
Re: Error Message F-26-3
Developer most likely needs to be replaced
Posted on Jun 20, 2008
0 characters
3 Points
Konica 7020
Did you blow it up, probably not.
Click this link for the everything.
  1. Choose the Category "Office Systems"
  2. Choose the model "7020"
  3. Click the error next to the Model dropdown box.
  4. Choose the 1876KB user manual called "User Manual for 7020, 7025, 7030 and 7035"
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
Dec 10, 2007 | Konica Minolta DiALTA Di200 Copier
Pixma iP2600 Photo Printer InkJet: Canon iP2600 error codes...
my printer will not print out anything. it starts to but the paper never enters into the printer, it is almost like it is jamed but it isn't.
The message says there is an error, push resume and try again.. same thing, it starts to push paper thru.. acts like a jam.. same message.. but paper is not jammed
May 16, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Check printhead path error message
the problem is nothing else but sofware..
you just reinstall the printer software.
Thank you
Sep 10, 2009 | HP DesignJet 1050c plus InkJet Printer
60.40 Error Message on HP Laserjet 5025 MFP printer
OK I had the hp error code some problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
Feb 22, 2009 | HP Printers & Copiers
Error message "servicer reqired 10"
Please email to for a solution. Mention the error message # 10
Feb 02, 2009 | GCC Technologies Elite 12/1200N Laser...
Black and color cartridges
have one black and one color cartridge in my printer but it keeps giving me an error message:
Oct 14, 2007 | HP Officejet 7210 All-In-One InkJet...
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Printers & Copiers Logo
376 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
