Question about Zenith C32C86R 32" TV
Bad picuter/color quality
The picture on the screen has a rainbow type effect of Blue,red, green and in the center is were normal picutre quality exists. whats wrong with this TV? The clors I mentioned start the sides in the maner I just described
Re: Bad picuter/color quality
Ive got the same problem, with my tv picture haveing a rainbow effect, but noticed, when my kids where watching there cartoons, a red flash fixed the colour in the area where it flashed,
im going to make a dvd with red flashes to see if this can fix it...
Posted on Nov 15, 2008
  • 51 Answers
Your problem sounds like it has to do with beam landing, or purity.
In a CRT type tv such as yours this can have many causes, some of which I'll describe.
- The CRT (picture tube) is magnetized, possibly by speakers being placed too close to the tv. Turning off an item such as a vacuum cleaner in close proximity to the tv can also cause the crt to become magnetized.
- The auto demagnetizing circuit has malfunctioned and requires a tech to repair
- The CRT has developed an internal fault and would need to be diagnosed/replaced. This is not worth the cost of repair.
- The yoke and/or beam landing magnets have become loose or faulty. This is internal and would require a tech to confirm or repair.
The only fault which you may be able to fix is if the crt has become magnetized. Check for sources of magnetism close to the tv. That would be such things as speakers or anything with a permanent unshielded magnet. TV's with CRTs have a circuit which demagnetizes the crt at each cold start. Turn the tv off and leave it off for 3 hours and then start it. If the crt is too magnetized or there is a problem with that circuit this may not work. You can also try a different placement, the ideal being the front of the screen pointing either directly north or south.
Posted on Nov 16, 2007
0 characters
3 Points
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Standard (CRT) Televisions
Picture is very green & blue very little red
if the picture have lost red, possibly there's a loose contact somewhere in C-board area of your screen. The only way to revive the red color is to check and resolder the c-board are.C-board is located at the back of the CRT unit.
Jan 14, 2009 | Standard (CRT) Televisions
I have a rainbow effect on my television screen.
the deguesing is not working of your tv.or maybe you have a load speaker near the tv. take it away near the tv it damage the color of your tv set.
Nov 15, 2008 | Standard (CRT) Televisions
Color displays in rainbow effect
Remove any speakers or electronic items that are near the set.
Jun 27, 2008 | Standard (CRT) Televisions
Bad color
If it is a glass crt then you need to have the set demagnatized with a demagnatizing coil. All tv shops have one. This is worth fixing and usually at the price of a service call.
Mar 15, 2008 | Panasonic CT-32SX12 32" TV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Faded and out of focus picture
Your TV has a burnt CRT base socket. Replace that, it is not a tough job, but make sure that you get the exact same type of base socket.
Jan 14, 2008 | Panasonic CT-34WX15 34" TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
Zenith C32C86R 32" TV Logo
207 people viewed this question
Top Zenith Standard (CRT) Televisions Experts
matt martin
matt martin
Anastasio Benjou
Are you a Zenith Standard (CRT) Television Expert? Answer questions, earn points and help others
