Question about Epson Stylus NX400 InkJet Printer
Error message saying cannot recognise ink cartridges
The epson printer gives an error message saying that it cannot recognise the ink cartridges
  • 355 Answers
Hello
Double check to see if the cartridges that came with your machine are really the correct ones. And if they are then make sure they are snapped in securely as they must make a solid contact to read the cartridges. Also make sure the drivers and software are properly installed onto your computer.Also make sure that the tape that is usually on the cartridges to protect them in handling and shipping are removed before installation.
regards
Posted on Jul 13, 2009
Epson printer CX9300 error B73 cannot recognise ink cartridge
A clone cartridge is a type of third-party ink cartridge that uses an identical chip to the original ink cartridge. People buy cloned cartridges to save money, since original cartridges are more expensive. However, sometimes the Epson printer does not recognize the cloned ink cartridge. After you install the cartridge, you might receive a message that says "An ink cartridge cannot be recognized." In this case, you will have to disable the Epson printer monitor.
Read more: How to Make an Epson Printer Recognize Clone Cartridges ' eHow.co.uk http://www.ehow.co.uk/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz1YgKjqw42
Instructions
    • 1
      Install your cloned ink cartridge into the Epson printer.
    • 2
      Go to "Start > Control Panel" on your computer.
    • 3
      Double-click on "Printer."
    • 4
      Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.
    • 5
      Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.
    • 6
      Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.
    • 7
      Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Mar 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Override error message re Epson CX3700 printer carridge
Hi
This is a common error message whenever you use a third party ink on an EPSON printer, one recommendation is that you can call epson for support to get a new one and ask if you can get a printer that uses the same ink for your cx3700- problem is on the hardware itself already. printer needs replacement.
Dec 19, 2009 | Epson Stylus C88 InkJet Photo Printer
Printer cartridge not recognised
if youre getting this message it means that the cartridge is incompatible with the printer why not use a genuine epson ink cartridge replacement ink sometimes ruin your printer or it damage the printer head
Nov 20, 2009 | Office Equipment & Supplies
Epson DX7450 won't recognise compatible cartridges
This is a common problem and is caused by faulty or missing chips onthe compatible cartridges. You will need to get them replaced otherwise the printer will not operate. Contact the vendor where you bought them from and ask for repalcements or a refund.
Sep 30, 2009 | Office Equipment & Supplies
Epson DX8400 does not recognise ink cartridge
on the ink cartridges there should be a little gold chip on them if they dont have that then your printer will not recognise the ink my best bet for you is to buy cheep and reliable placement epson ink or you can buy these ink cartriges which have tubes which feed ink into these replacement cartridges and i have got one of these my self and i would recomend these to anyone
Apr 15, 2009 | Epson Stylus DX8400 All-In-One InkJet...
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
I have replaced the black cartridge with an approved epson T0711H.Now my printer says it cannot recognise any of the cartriges and is giving an error message to that effect.I have taken the cartridge out...
Suggest a logic reset by pulling the plug out of the wall. Shutting off the power at the printer DOES NOT reset the logic.
After 5 minutes re-connect plug to power and power up printer as normal.
If the above does not work, try again, but pull ALL cartridges out. Clean the copper pad of any residual ink. Re-install cartridges after printer power up.
Feb 24, 2009 | Epson Stylus C86 InkJet Printer
Problem using sublimation inks
Since you are using sublmation ink, the cartridges are probably aftermarket and may not meet Epson standards. Aftermarket chipped cartridges are notorious for failing to 'communicate' with Epson printers, even when the cartridge is brand new. Before taking the printer to a service center, you might try purchasing new cartridges of your ink from your reseller. If that fixes the problem then your fight is with the ink reseller, not Epson. If it doesn't fix the problem and your printer is still under warranty, take it to an authorized service center, and remember, using non-Epson ink does NOT void the waranty.
Jun 16, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson RX560 ink cartidges not recognised
Report this to Epson Support.
Remove all cartridges and switch the printer off
Reinsert and retry.
Download the Epson utility www.ssclg.com
and use it to Reset counters.
Feb 11, 2008 | Epson Stylus RX560 All-In-One InkJet Photo...
Epson Stylus NX400 InkJet Printer Logo
371 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
