Question about Karcher 2500 PSI Pressure Washer
I have an Excell VR2522 that will not start after sitting for a while. Tried pulling the cord and it would pull okay for a while, then it tightened up to the point that I could barely pull the cord. Any help?
  • ryan_c_grove Jul 14, 2009
    Thanks for the response, but that's not the problem. When I put the washer away, it was fully drained, the gun and hose were both disconnected, and the gas was drained. Put new gas in, got the water running through the PW and hose/gun, but the pull cord is VERY hard to pull now. It wasn't at first, but after pulling quite a few times trying to get it started, it has become extremely hard to pull the cord.
  • 104 Answers
SOURCE: no pump pressure
Sounds like the diaphragm in the pump unit has failed, the engine and the pump are two seperate things the engine only operates the pump but if the diaphragm is leaking or broken you wont get any pressure
Posted on May 23, 2009
sailoff
  • 8 Answers
SOURCE: Pull cord is locked. Was running fine and just
any oil in the engine? pull cords are easy to replace but sounds like you run out of oil and the engine locked up!
Posted on Jun 21, 2009
SOURCE: fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Posted on Jul 20, 2009
SOURCE: excell vr2522 - picked up 2nd hand, cant figure
use the black tip or lowest pressure one that should solve your problem
Posted on Sep 12, 2009
  • 1383 Answers
SOURCE: mi maquina luego de varias
Dispense porque mi espanol no es muy bueno aci como usted. El presion comiensa con el nozzle. Nozzle debe de ser el que fue hecho para la machina. El nozzle debe de tener el numeracion de gallons por minuto marcado. Su machina sera marcado con (gpm) gallons por minuto. 2.5 or 3.0 or 3.5, Y si el abuhero de el nozzle es muy grande, no va tener presion. Tambien, no debe de tener agua tirandose de connections. Y se el presion es muy bajo con el correcto nozzle, va a tener que combier partes adentro de la pompa. Y si ya tiene bastantes horas corridas, sera mejor combier la pompa entera.
Posted on Nov 11, 2010
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
I serviced the carburetor and i cannot get the pull the start cord
Make sure you have assembled the starter correctly, assemble loosley pull the starter handle until you hear the pulley fully engage into the starter pawls on the flywheel and the cover sits down easily, now fully tighten the screws.
Feb 10, 2013 | Solo 450 Mist Blower
How to replace wheels on Excell VR2522 pressure washer
Anon, The wheel is probably held on by a push nut/cap. The easy way to remove is to cut through the cap retainer with a dremel tool part way and pry off with screw driver, these caps are not normally reusable after removal, check hardware store for replacement.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DeVilbiss Excell VR2522 Type 0 Gas Pressure Washer Parts
Remove CM 1200 Lawn Mower Wheel Retainer Clip on Lawn Mower Wagon Carriage...
https://answers.yahoo.com/question/index?qid=20130208122204AAcj7mW
Jan 28, 2013 | Garden
Excell vr2522 pull cord jammed
Is the garden hose connected and turned on?If so make sure that the trigger on the gun is being pulled while your trying to start the engine! The backed up pressure in the high pressure hose can mimic a blown or seized engine in this situation.
Apr 15, 2012 | Garden
Have an Excell 2500, VR2522...... Pull cord broke and now i think the spring is broke; where can I get a new spring and directions to reassemble the pull start?
That pressure washer uses a Honda 5.5 hp overhead cam engine
You need to get the model number of the Honda Engine and then Click Here to go to the ereplacementparts.com website and put the engine model number to order the parts.
Jun 23, 2011 | Garden
I just bought a used Excell VR2522. The guy I bought it from said that it worked great (of course). I did have him demonstrate it to me and it seemed to work fine. The motor started right up and the...
yes you have a bab pump if you want i can get ya one cheper than what most pepole can shoot me a e mail with your phone number and ill callya and price ya one tthanks mickey
Aug 30, 2010 | Garden
Excell r 2522 presure washer pump rebuild
I like http://www.ppe-pressure-washer-parts.com/excell-vr2522-replacement-parts-pump See pump upgrade and compare to rebuilding. Another good site is www.pressure-washer-parts.com. Piston seals usual begin by overheating from excessive idling. You might add a thermostatic relief valve to help this.
Jul 25, 2010 | Honda Garden
Fuel mix for a excell VR2522
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
No pump pressure
May 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
775 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
