Televison & Video Logo
A
Anonymous Posted on Nov 04, 2015
LG 42LV5500-UA LED TV turns on, but has no picture or sound
Found a training manual, but my tv has an extra board (LED address, maybe?) not shown. Tried the power supply test procedure in the manual - jump standby to power on pin. Backlight is not supposed to light, but it does.
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Nov 04, 2015
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986515
Points
237762
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault to its main board. Short circuited component/s at it.
1helpful
2answers
My TV is a LG 47LN5700-UH I had a lightning strike near the house. Afterward TV would start but not boot completely. Now it won't start at all. Cable box also got fried at the same time.
The led driver AND the T-con board are bad. If you could see a picture with the flashlight then the T-con board would be good. It is not. The led driver can be on the main board or the power supply board. You can get these parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
1helpful
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
1helpful
I have a LG 42LV5500-UA LED tv with a black screen. Power light comes on but that is it. Any ideas on what board needs to be replaced? right in the middle of a program went black.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
How to repair LG LCD TV 47LG70-UA no picture or sound
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
1helpful
Why does my TV have no picture but still have sound? Its a LG LED Tv Model number 42LS3400-UA prod code 42LS3400-UA.APHLJD Serial number 2101NBSB2837 When turned on there is sound but no picture.
the picture board has gone faulty
thee are two system boards in the set --one for sound and one for picture
if you have the number from the board you want to replace try e-bay --circuit boards for your tv and see what comes up
LG 26LX1D won't turn on.
My LG 26LX1D is the UA Version.
The solution for my problem was unclogging the Small Fan by the Main Panel, on the opposite side of the TV as the Power Board.
This is My Story.
The TV I found at the dump seemed good, but would not turn on.
Two LED's showed up on the front panel of the Television. First, the Red LED (on, off), then the Green LED (ON), then the Red LED (blinked) while the Green was still on.
I removed the back panel and saw that there were NO SIGNS OF BAD CAPACITORS on the Power Board. I plugged in the TV once more to see what would happen.
I noticed that there was a SMALL FAN which did not move when I plugged the power source to the outlet. This Fan was CLOGGED WITH DIRT.
I unscrewed the Fan from it's place and set it on a dish to act as a buffer against the main board. I then proceeded to clean it with a Vacuum Cleaner and a small Flathead Screwdriver.
I now own a FUNCTIONING LG 26LX1D-UA, RESSURRECTED!
4helpful
2answers
LG "NO PICTURE" , IF FIX WILL RECUR? ,DID LG FIX DESIGN FLAW 42PC3D
I had same problem - no picture, but sound worked - LG 42PC3d - was two months past warranty, but LG agreed to fix it as a warranty call. Service guy was out within a week to replace the Z SUS(?) board. Works fine now. This must be a typical problem, as LG did fix it, even though the warranty had expired. Good luck.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
