Question about Frigidaire ATF6000ES Front Load Washer
Started a load of wash. After apprx 30 seconds I turned it off, opened the door to place a rag in it. It will show the door lock light but will not start or dispense water.
  • 6,784 Answers
HI, check the connections that link the door lock switch mechanism to the actual control board(main). if the connections are in good condition and, the harness is not fouled, replace the door lock switch mech. it has failed.
Posted on Jul 13, 2009
My LG WM1832CW will not start.
It looks like the door switch is bad
Apr 04, 2014 | Washing Machines
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Everything seems to work, door locks, but water won't flow
Check the water solenoid valve, it may have failed. A quick test is to use hot wash rather than cold wash. If the hot water works, then your cold water valve has failed.
Jul 02, 2009 | Kenmore 46462 Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Door buzzing/not locking
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Whirlpol duet
sounds like your door lock switch may not engage.try opening and closeing the door. unplug the unit wait a few minutes plug back in and see if you can open the door. check to see if the door lock lights up.. hope this helps..
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
144 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
