F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
www.repairclinic.com
thanks.
