Question about Minolta EP4000/5000 CS/PRO Copier
Touchscreen and coalator connection
Touchscreen is very hard to read and I cannot connect properly the coalator to copier
  • 31 Answers
The back light on the display panel has burned out. I'm not sure if the LCD assembly is even still available for this model. Before we completely discontinued servicing this model, we couldn't get them anymore from minolta. The last one I replaced was about six months ago and I had to get the replacement part off a junked machine in the warehouse.
Posted on Jul 16, 2009
Touch screen not working
If the touchscreen does not have any damage then remove all the screws and remove the touchscreen if it comes out freely, the connection has come out from the slot, if not please press it in the slot properly it should work. if doesn't work the connection strip is damaged.
Mar 21, 2014 | Cell Phones
New coby touchscreen video mp3 player wont come on
The battery might not be connected or attached properly.
either to the device or to the charger (when you charged it).
you could try and fix it yourself or ask a repair shop.
Jul 25, 2012 | Coby 2.8-Inch LCD Touchscreen Video MP3...
Sharp AR-M550U code:E7-03
The E7-03 error code means the HDD is not properly installed or is dead. You can check the connections on the HDD and the MFP Controll PWB. You can also use Simulation 62-2 and 62-3 to check the read/write of the hard drive.
Sep 07, 2011 | Sharp MX-2300N Color Copier
Copier reads e7-03
E7
Content HDD trouble
Detail
HDD connection failure
If the HDD responds an error or does
not respond for 30sec, it is judged as
an error. (Other than the system area)
Data abnormality in the file
management area (when the cluster
chain is broken)
Cause
HDD is not installed properly to the ICU
PWB.
HDD does not operate properly in the
ICU PWB.
ICU PWB trouble
Check and
remedy
Check installation of HDD to the ICU
PWB.
Check connection of the harness of
HDD to the ICU PWB.
Use SIM 62-2, -3 to check read/write of
HDD.
Replace HDD.
Replace ICU PWB.
Aug 05, 2011 | Sharp MX-2300N Color Copier
Touchpad won't respond to touch, know how to fix?
that is the touchscreen/touchpad is broken.
or usually problem with flexycable which to connect between touchscreen and PCB.
the solution. - you must replace a new.
but if you buy they are one set.
price about $30 - $37.
May 17, 2011 | Office Equipment & Supplies
I have a samsung gt s5233 w edge and the touchscreen has failed. the left and right part of the screen is not functioning anymore. but when i press at the center, the right side of the screen activates....
check the conector of the touch, if the touchscreen connector is not connected properly just unconnect and connect properly ,if it does not work buy a touchscreen.
Mar 13, 2011 | Samsung Star GT-S5233 Cell Phone
The touch screen does not respond to touch except for one small spot in the upper left corner where it says "job list". Can not log on to copy
Due to the environment, over time conductivity of the touchscreen connection deteriorates because of high temperature or high humidity. Consequently, the area between the conductive cover and glass expands and loses connection. Today, The Touchscreen has been modified and should be replaced when the symptom occurs
Jan 30, 2011 | Konica Minolta bizhub C250 All-In-One...
Hard Drive not recognized by laptop
The Hard Drive could have come loose from the SATA or PATA connection, or your Hard Drive could have simply died. If it is still under warranty; replace it. If it is out of warranty; open the external casing and check that the HD is connected and / or test the HD in a separate external casing or Desktop that you have. If it is connected and the external casing is working properly (or Desktop is booting properly and can read it), then you have a dead Hard Drive and will have to buy a new one.
May 03, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Disk read error
kindly chek the drive connection make sure the cable is properly connected if possible then change the power connector of the hard disk.and boot the system in safe mode and go to command prompt and type chkdsk /r /f and restart the system.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 22, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Operating system not found.
The hard drive has either been damaged and can't be read, or its connection was knocked loose from the motherboard. Open whatever cover necessary on your computer to get at the hard drive and make sure any connecting cables are properly seated. If the drive was damaged by the fall you will need to replace it and restore your system.
Apr 05, 2009 | Fujitsu (MHV2120AH) 120 GB Hard Drive
53 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
