Question about Zanussi ZBQ665 Electric Single Oven
Zanussi ZBQ 965(X) Built-in Oven
Yesterday whilst using the oven, a 'pop' was heard and the oven no longer functions correctly.  When swicthed on, the led lights show, but none of the actual oven modes start up, and PY 2 is shown on the display.
After phoning Zanussi technical help, no one can diagnose the problem over the phone so i though here would be the next place to ask...
Regards,
Michael
    New Friend:
Oven no longer works no lights on clock , hob works which is on same feed ?
Posted on Feb 12, 2010
  • Zanussi Master
  • 3,463 Answers
Sounds to like the oven element has gone, the red light indicates that power is going to your thermostat o/k.
Check the oven element.
Posted on Dec 10, 2008
SOURCE:
My zanuzzi inbuilt ovn model zob k92 qx product number 949711644 has gone in to safe mode , do you know how to get it to work again ?
The child safety function
In order to avoid that children engage oven, it is possible to lock the oven controls. Press the two keys (as shown) and hold them for at least 3 seconds. The beep and "SAFE" on the display indicates that the child safety function is activated and it is not possible to select the temperature or a function of the oven.
To unlock the oven press the two keys (as shown) and hold them for at least 3 seconds. You will heard beep and indication "SAFE" will be disappear. Now you can operate the oven.
Dado
Feb 22, 2015 | Zanussi Ovens
Fan oven making a noise when turned on
Hi I have never heard of your type of oven . alwasy remove power then most ovens the fan comes out from the rear , then clean with fantastic be carful not to bend the fan blades that should correct your problem
Dec 09, 2011 | Zanussi ZBM799X Electric Single Oven
Zaunssi ZBF360X built in Oven Not Heating
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 30, 2010 | Zanussi ZBF360X Electric Single Oven
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Zanussi built-in oven ZDF 866W socket blows when turned on
sounds as if a wire to the fsd is shorting when oven turned on.
Sep 28, 2009 | Ovens
We have a Zanussi built under oven (ZUF270). Last
You could but if you disable the timer and anything goes wrong with it could invalid your house insurance if anything went very wrong.
Jan 09, 2018 | Zanussi ZHQ575 Electric Double Oven
Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
Nov 17, 2008 | Ovens
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZBQ665 Electric Single Oven Logo
515 people viewed this question
Top Zanussi Ovens Experts
gunfai
Level 1 Expert
David Ellis Rhea
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
