Question about Maytag PAV2300 Top Load Washer
Maytag washer - the water will not stop running
I had to shut it off at the valve.
    President:
  • 704 Answers
Typical symtom of a faulty water inlet valve. Usually due to hard water deposits or sediment building up in the valve over time and causing it to slow leak due to wear. However, don't forget to first tighten the hoses on the inlet valve to make sure they're tight. Also, check the washer in the hose ends as they might be brittle, old and cracked allowing dripping to occur. Otherwise...
The best solution is to get a new replacement inlet valve set, as they are supplied as a unit for the hot and cold water valve. Typically an fairly easy repair to perform and will save yourself some money versus having a service tech do the job for you.
Here's a parts diagram and I believe you're looking for item #17 at around $40, BUT you need to make sure that is the correct part for your particular model, as the numbers vary, etc. Hope that helps!
Copy all of the link and paste into your browser to view, or just go to www.searspartsdirect.com and enter in your product's info.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=PAV2300AWW&productCategoryId=0153200&brandId=3048&modelName=WASHER&diagramPageId=00003&componentDescription=CABINET&documentId=M0606007&backToLink=Return to Sub Components list
Posted on Jul 13, 2009
  • 583 Answers
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to. the another possible fault can be ------------ The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Water stops running before the machine is full
Check on the inlet valve and also the pressure switch.If the power had stopped to the inlet valve which had shut the water supply then the program controller unit must be checked. remove power and reset and try again.
Jul 04, 2012 | Maytag Legacy Series Top Load Washer
Water will not stop running during cycle. the code says it water pressure but you have to shut off the water to make it stop
It could be one of two things. If the water runs into the machine even when the washer is turned off, you need a new water valve. If the water only comes in when called for then doesnt stop you need a new pressure switch and possibly a new pressure switch hose
Jul 12, 2011 | Maytag MAH8700A Front Load Washer
I have a Maytag (FAV6800AWW) top load washer. The cold water won't shut off except at the valve. The cycle will run properly with hot water but if you have the cold on it just runs until it...
the water valve is bad in the rear area inside the machine,its controlled by electrical solenoids and the valve is stuck open even with the unit shut off,replace the valve combo hot and cold as these dont repair
May 29, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer runs and runs water, no stop.
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Apr 28, 2010 | Maytag PAV3240A Top Load Washer
On my Maytag Neptune MAH-3, the water is running non-stop
check plastic hose out side of tub to pressure switch
if ok replace pressure switch
Oct 12, 2009 | Maytag Neptune Washer
When the washer is filling it doesn't shut off and runs over.
Hi, Will the water stop if you cit the power to the washer or does it still run? If it shuts off when the power is off to the wsaher, you will need to check the water level switch. If the water continues when the power is off, you will need to change the inlet valve. Please let me know if this helps or is I can assist you further.
Vic
Jul 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Water won't cut off
if you have to shut the water off at the source you need a new water inlet valve. If not then you need to replace the pressure switch.
Jan 29, 2009 | Maytag MAT13MN Top Load Washer
My Maytag Washer keeps running water and won't stop.
regardless of machine being on or not???sounds like a faulty water inlet valve youll need to replace the valve..
If the water level just overfills and floods over the top of washer but turns off when the unit is shut off, then it sounds like a bad fill switch.
May 10, 2008 | Washing Machines
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Water won't stop running
It might have a small stone or something similar in the water soleniod valve or it might just be sticking open somewhat. I'd go ahead and change the cold water soleniod valve because it's not closing itself and shutting off the water flow.
Jan 08, 2008 | Maytag Performa PAV2200
Maytag PAV2300 Top Load Washer Logo
638 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
