Question about Electrolux EOB6636X Ultrafan Electric Single Oven
Electrolux EOB5630 Hi, was baking and power cut off in house. now oven will not heat up. grill, light, and fan work fine. any idea of what to do? thanks
  • 41 Answers
Re: electrolux EOB5630
Not sure that I can help but will certainly try. You need to check to see if the power is getting to the oven. As the grill, light and fan are working it seems that it is. With the Oven not heating up I would suggest that it is possibly the Oven Element. Usually to check these you need to remove the cover inside the oven and also the back cover. You will probably find the power is getting to the element but the element is not working and needs replacing. Before removing it MAKE SURE YOU TURN OFF THE POWER TO THE OVEN. Should only be 2 or 3 wires going to the element which will need to be removed before removal. Usually only a couple of screws hold the element in and once removed you may have to wiggle the element a little to get it out. Replacement is just a reversal of the removal procedure. I had to replace the one in our oven 2 weeks ago as we had the same problem. It is fine now and was only the element. Just MAKE SURE you TURN OFF THE POWER before removing the element. Hope this helps.
Posted on Feb 24, 2008
0 characters
3 Points
How many elements are there
If you ask how many heating elements is there then my answer is two. Upper heater element with grill heater (1000 / 1900W) and ring heating element (2400W) that is positioned around the convection fan.
Jun 27, 2014 | Electrolux EOB5630 Ultrafan Electric...
What is the diference between an EOB5630, and EOB5630B, an EOB5630x etc. I have an EOB5630 oven fan element to replace but need to be sure I get the right one. Are these models interchangeable??
I would guess they are the same element in Australia the last letter in electrolux ranges signifies the color or type of clock fitted the B would be for Black ovens the X would be a multi function oven they all have the same fan element
May 29, 2011 | Electrolux EOB5630 Ultrafan Electric...
Using my EOB5630 oven went bang
the fan element will have shorted out. if you remove the panel from inside the oven you may see where the circular fan has shorted. It will have blown a fuse poss in a plug if connected that way.or tripped a circuit breaker. remember to set the clock when power is restored as it wont work until you do.
Jul 29, 2010 | Electrolux EOB5630 Ultrafan Electric...
Our electrolux eob5630 oven keeps turning off
its the thermal cut out. replace it. ISOLATE oven.
slide oven out a few inches, remove knobs, remove front panel(two screws)
you will only be able to pull panel 3-4" due to wires.
Cutout has 2 blue and 2 white wires..
you may need to snip a couple of cable ties.
Put new cutout in one wire at time( easy to forget where they go)
Tidy up wires. Put cover back. Secure oven in hole.
Turn on power. Reset clock(otherwise won't work)
Done 10 minute job
Jul 19, 2009 | Electrolux EOB5630 Ultrafan Electric...
Electrolux oven wont heat up after power cut
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
May 15, 2008 | Electrolux EOB5630 Ultrafan Electric...
The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Mar 01, 2008 | Electrolux EOB5630 Ultrafan Electric...
Electrolux EOB6636X Ultrafan Electric Single Oven Logo
271 people viewed this question
Top Electrolux Ovens Experts
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
