Question about Casio XJ-360 Multimedia Projector
My projector will run for a time between 20 minutes and 2 hours and then it shuts down. It will start right back up (takes 3-5 minutes for it to cool and then restart) after that. What could be wrong?
  • 37 Answers
It could be overheating. Can you hear a fan running? Does the projector feel hot to the touch?
Try putting a small house fan on it to cool it and see if that helps.
Posted on Jul 13, 2009
Unit is shutting down after ten min
My unit never got to the point of actually shutting down due to overheating, but your problem may be related to what I experienced: A bent lamp heat shield.
My Optoma EP739 started exhibiting color-banding and strong color shift after years of great service. After trying other suggestions that didn't work, here is the FIX for my unit. I have not seen this posted anywhere else.
Problem: After 10-20 minutes of use, color-banding and then a strong shift to purple/green with almost no red. If the unit is turned off for 5-10 minutes to cool and then powered-up again the problem goes away, only to come back in another 10-20 minutes. Enabling the "High Altitude" setting in the Setup Menu helped for a while (a week or two) since it forces the main cooling fan run at high speed always, but then the problem re-appeared.
Reason: Overheating. The electronics are overheating. Like several people have suggested: First step: Open the unit up and blow-out/vacuum all of the accumulated dust. Assure BOTH fans (there is a small drum blower directly cooling the lamp and a larger regular fan that circulates air through the entire unit) are operating and clear of debris.
Once you have done that, then look for the REAL issue. With the front panel (i.e.the panel with the hole for the lens) removed and looking into the projector from the front examine the metal heat shield on the right side above the lamp. In my unit, because of years of service and heat, the aluminum lamp housing had deformed slightly, tilting this sheet metal heat shield directly INTO the air stream from the fan. This restricts the airflow enough to reduce cooling capacity. This metal shield should be high enough above the lamp to be TOUCHING the plastic case. If it is bent down and is halfway into the air stream then it restricting the exhaust airflow, causing the overheating.
Fix: Bend the heat shield back up so that it is not in the exhaust airflow. It must be ABOVE the airflow, protecting the plastic case from the heat of the lamp. This simple remedy fixed the issue for me. My projector has been running 2-3 hours a day for 10 days now with no banding issues at all. That's it. Simple fix.
Feb 01, 2013 | Optoma EP739 Multimedia Projector
NEC NP 1150
The temperature in the classroom is to hot. Turn down the
temperature in the classroom or get a small fan and place it near the
projector. The projector is running at border line and just needs a few
degrees of cooling...
Jul 20, 2010 | NEC NP1150 Projector
Flashes change lamp after a couple of hours run
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 02, 2009 | Sharp ANXR1LP Projector Lamp for XR1X,XR1
BENQ mp720 stops after 20 minutes and needs to
clean out the dust with canned air and make sure the fans work. if the lamp and power board can't cool down, it shuts down to prevent damage.
Sep 22, 2009 | BenQ MP720 DLP Projector
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Runco Cl 610 keeps shutting down
on the cl-610 it would shut down after about 5 minutes of running..as well as having to replace the customers bulb. so I took a look at the cooling system there are two fans which work fine, but there is a type of vent inside attached to the body of the projector it seems to have some back pressure if my words are right causing the fans to return the heated air back into the projector forcing the fast shutdown and lessening the life of the bulb. so as a test I removed the directional vent and I blew into it and most of the air came back rather that went out so I left it out and the projector has been running flawless for the last two days. might be time for a redesign on that directional vent cover. but check it for yourself first. if this has helpped please let me know.
Nov 27, 2008 | Audio Players & Recorders
After driving for 25-30 minutes, the car won't start for about 3 hours
Any chance you've got 'Titanium' spark plugs. We had this same issue, and found it was caused by a mechanic replacing our plugs with the titanium ones. If they were hot, they didn't ignite properly during startup. If you let the car cool, it would start right up (~2 hours). Changing the plugs for good quality old-style plugs and the problem hasn't occurred since.
Aug 01, 2008 | 2000 Saturn SW2
Projector restarts after 30 minutes or so
Hi jamble77
This sounds like a faulty Ballast ( lamp's powersupply ) if it made a grinding noise and now the Projector shuts on and off intermittently.
I would advise you to rather have the part replaced than repaired , as in most cases the Ballast almost always returns with the same problem if repaired a couple of months down the line.
May 20, 2008 | Panasonic PT-AE900U Multimedia Projector
Casio XJ-360 Multimedia Projector Logo
191 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
