Question about Panasonic SC-EN7 CD Shelf System
All functions turn on, but i can listen to music. The output integrated circuit is broken
I unknown the output integrated circuit of this product, because the defective is unreadable. Please send me the part number to buy it. Thank you
  • Oscar Alberto
    Oscar Alberto Nov 26, 2007
    I can`t get the service manual, that`s impossible on this country (Argentina).
    Thanks
  • Oscar Alberto
    The manufactrer is PANASONIC and the model is SC-EN7.
Hi there OSKY,
I would suggest that you try and obtain the service manual for this system of yours. Usually from the manufacturer or an alternative source.
The model number and the manufacturer are listed on the rear panel of the sound system.
Once you get the service manual it will list the correct part number and the type of IC installed in that particular model..
You havent listed the model or manufacturer for me to search my own service manuals , so I cant provide you with the IC part number...without a good description of it..
Cheers YUBEUT...
Posted on Nov 24, 2007
2003 buick fuse
Table 1: 4-Wire Ignition Switch Table
The body control system consists of the following 3 modules:
• The dash integration module (DIM)
• The instrument panel integration module (IPM)
• The rear integration module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each of the modules are connected to the Class 2 serial data line; many control signals are implemented by Class 2 messages.
Dash Integration Module (DIM)
The DIM is wired to the class 2 serial data line. The various DIM input and output circuits are described in the corresponding functional areas as indicated on the DIM electrical schematics.
The DIM functions include the following:
• Control of headlights and exterior lamps
• Horn relay control
• Interior lamps incandescent dimming
• Lamps On signal with wiper/washer
• Power moding control over Class 2 serial data line
• Steering wheel controls
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules
Apr 21, 2018 | Buick Cars & Trucks
Where is the body control module located on 2002 cadillac deville
• The Dash Integration Module (DIM)
• The Instrument Panel Module (IPM)
• The Rear Integration Module (RIM)
Each of the 3 body control modules integrate a number of functional systems under the control of a single module. Each module is connected to the Class 2 serial data circuit, many of the control functions are implemented by Class 2 messages.
What system (S) are you having problems with ?
The various RIM inputs and outputs are described in the corresponding functional areas as indicated on the RIM electrical schematics.
The RIM functions include the following:
• Automatic level control
• CIGAR relay control
• Class 2 communication requiring RIM interaction
• Content theft deterrent
• Fuel door control
• Fuel level sensor input
• Heated seat control
• HVAC blower control
• LK/CYL relay control
• Park brake relay control
• Rear defog relay control
• Rear park assist chime control
• Retained accessory power (RAP) relay control
• Reverse relay control
• Transmission shift inhibit
• Trunk release relay control
• Various controls for the interior lamps
Instrument Panel Integration Module (IPM)
The various IPM input and output circuits are described in the corresponding areas as indicated on the IPM electrical schematics.
The IPM functions include the following:
• 54 volt VF display input
• Ambient light sensor input
• Class 2 communication requiring IPM interaction
• Fog lamp switch inputs
• Front HVAC air delivery controls
• Front HVAC sensor inputs
• Front HVAC temperature controls
• Fuel door and rear compartment lid release switch input
• Hazard switch input
• HUD active control
• Instrument panel lamps dimmer switch input
• Ignition switch headlight control
• Interior lamps switch input
• Key in ignition switch input
• Traction control switch input
• Twilight sentinel delay input
• Class 2 communication requiring DIM interaction.
• Control of exterior lamps.
• Control of front fog lights.
• Control of the headlights.
• Headlamps on with wiper input.
• Hood ajar switch input w/export.
• Horn relay control.
• Interior lamps incandescent dimming.
• Low side temperature for HVAC compressor.
• Power moding control over Class 2 serial data circuit.
• Reverse lockout solenoid control.
• Steering wheel controls input.
• Storage of the clock settings and, sending a message out on the class 2 serial data circuit in response to requests from other modules.
Jun 19, 2017 | Cadillac Cars & Trucks
What does bmc mean and what is it for on 1 2001 buick lesabre
BCM - body control module a computer that controls functions on your vehicle . A BCM controls light's , power door lock's , anti-theft system control , Remote keyless entry , headlamps . On your vehicle three modules make up the body control system .
Serial Data Power Mode
On vehicles that have several control modules connected by serial data circuits, one module is the power mode master (PMM). On this vehicle the PMM is the DIM. The PMM receives 4 signals from the ignition switch.
To determine the correct power mode the PMM uses the following circuits:
• Accessory voltage
• Ignition 1 voltage
• Ignition 3 voltage
• Off/Run/Crank voltage
The RIM is wired to the class 2 serial data line. The various RIM input and output circuits are described in the corresponding functional areas as indicated on the RIM electrical schematics.
• The ajar switch and tamper switch inputs from the rear compartment lid
• The automatic level control
• The cigar lighter relay control
• The fuel door lock and release control
• The heated seat controls
• The park brake relay control
• The rear compartment lid release controls
• The rear defogger relay control
• The retained accessory power (RAP) relay control
• The reverse lamp relay control
• The various controls for the interior lamps
Mar 21, 2017 | Buick LeSabre Cars & Trucks
Having trouble with all my speakers except my twitters in a 2007 Saturn Outlook...what do I start with? Fuses are good
Speakers get power from the amp if your system has one or from the radio , if the tweeters work it's not a fuse problem . You like listen to your stereo loud . Blew a channel in the radio or amp ?
Take it and have it checked for DTC'S - diagnostic trouble codes
DTC B1025 01: Audio Output 1 Left Front Circuit Short to Battery
DTC B1025 02: Audio Output 1 Left Front Circuit Short to Ground
DTC B1035 01: Audio Output 2 Right Front Circuit Short to Battery
DTC B1035 02: Audio Output 2 Right Front Circuit Short to Ground
DTC B1045 01: Audio Output 3 Left Rear Circuit Short to Battery
DTC B1045 02: Audio Output 3 Left Rear Circuit Short to Ground
DTC B1055 01: Audio Output 4 Right Rear Circuit Short to Battery
DTC B1055 02: Audio Output 4 Right Rear Circuit Short to Ground
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier (if equipped) have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5 V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3 V AC and slightly higher.
Do you know how to do DC voltage testing ?
Without Amplifier without UK6
Ignition OFF, disconnect the harness connector at the appropriate speaker.
Radio ON, test for 5.0-7.5 V between the signal circuit terminal A and ground.
? If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
? If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
Test for 5.0-7.5 V between the signal circuit terminal B and ground.
If all circuits test normal, replace the speaker.
Dec 25, 2016 | Saturn Outlook Cars & Trucks
I have a 2010 cobalt lt. Today both my feont speakers quit working. And now my turn signals make no noise. Or the door chime or the seatbelt indicator does not work. What causes this and how do I fix it?...
The chimes an turn signal noise come out driver door speaker . Both front speakers not working could be a blown circuit fuse inside the radio or just blown front speaker channel . Your best bet , take it to a GM dealer or someother qualified repair shop . You have no idea of the complexity of this . The radio can set DTC'S - diagnostic trouble codes , believe it or not !
DTC B1025, B1035, B1045, or B1055
Each of the audio output channel circuits (+) and (-), at the radio and audio amplifier have a DC bias voltage that is one half of the battery voltage. When using a DMM, each of the audio output channel circuits will measure approximately 6.5V DC. The audio being played on the system is produced by a varying AC voltage that is centered around the DC bias voltage on the same circuit. The AC voltage is what causes the speaker cone to move and produce sound. This voltage will vary depending on what type of audio is being listened to, talk or music, and type of music, as well as the volume setting of the system. Low volume and talk settings will measure around 1V AC and less, where constant music may measure 3V AC and slightly higher.
DTC B1287 01: Amplifier Control Signal Circuit Short to Battery
DTC B1287 02: Amplifier Control Signal Circuit Short to Ground
DTC B1287 04: Amplifier Control Signal Circuit Open
The radio provides a remote amplifier mute output circuit to control overall muting of the remote amplifier. The amplifier receives pulse width modulated (PWM) signals on the control circuit at varying duty cycle percentages for controlling muted and unmuted functions of the amplifier. Circuitry internal to the radio monitors the remote amplifier mute circuit for faults and sets the appropriate DTC when faults are detected.
Feb 16, 2018 | 2010 Chevrolet Cobalt
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
No audio output. muffled output from Phones jack
you need to check the power supply of the amplifier with the help of a voltmeter. if that is OK the power amplifier IC(integrated circuit) is gone bad, see for overheating of IC.
Sep 26, 2011 | Roland Ac60 Acoustic Chorus Guitar...
Want to watch movies
Looks like it only plays .mtv files, so a converter may be needed before uploading video files to the 610.
Try these links for converters, info, etc.:
http://www.imageconverterplus.com/help-center/about-icp/supported-formats/mtv/
http://www.openwith.org/file-extensions/mtv
http://www.sharpened.net/extensions/file/mtv
Product Description: Coby MP6104GBLK MP6104G 4GB Color Display Flash MP3 Player Radio.
1.8 inch color LCD display.
Integrated flash memory.
Plays music, video, photos, and text.
Integrated FM radio.
ID3 and LRC support for song and lyric information display.
USB 2.0 Hi-Speed for fast file transfers.
Integrated rechargeable battery.
Color: Black.
Memory Capacity: 4GB.
Display Type: 1.8 inch TFT LCD.
Display Resolution: 128 x 160.
Media Support: Integrated Flash.
Format Support: Audio: MP3, WMA; Video: MTV; Photo: JPG; Text: TXT.
OS Support: Windows Vista/XP/2000.
Menu Language Support: English, Spanish, French, Portuguese, Italian, German.
Additional Functions: FM Tuner.
Audio Output: 3.5mm Headphone.
PC Interface: USB 2.0 Hi-Speed.
Power: Integrated Rechargeable Lithium Polymer Battery.
Battery Life: Capacity: 350mAh; Audio Play Time: 8hr.
Unit Dimension (WHD): 1.65 x 3.66 x 0.38 inch.
Helpful?
Mar 23, 2011 | Coby MP-610 MP3 Player
My toster does not ssstay in ON position. The IC with mark 63AB1B (2x9pins) probably broken. Can somebody tell me what is this IC and where I can get its datascheet. I tried internet with the number...
An integrated circuit constructed to provide control functions to a toaster oven cooking appliance. The control functions including compensation for input voltage fluctuations, compensation for residual heat due to recycling, audible signal generation, multiple mode selection, safety shut off and others. The integrated circuit also provides flexibility to accommodate multiple models of an appliance in a product line. If you have the tools and the part, you can fix it yourself otherwise to the repair shop
Oct 29, 2009 | Russell Hobbs 10617 Glass 2-Slice Toaster
CMT-RB5 - No Sound
your set as a problem in the audio circuit. the audio ic or transistor output needs to replaced.call a tech to do the repairs.good luck.
Apr 11, 2007 | Sony CMT-RB5 Shelf System
Panasonic SC-EN7 CD Shelf System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
