SOURCE: Canon Laser Printer LBP5000 Need to Reset the printer
If it's a remanufactured cartridge take it back and exchange it for one that works.
SOURCE: Paper jam
just remove all cartridge and u will find the stell plate wich is movable from there u can remove the paper
SOURCE: canon x25 toner cartridge
Don't try and refill this on your own, you'll only have difficulty. Buy a reasonably priced compatible, that is "remanufactured" -not 'refilled'. It's not just toner that makes it work. The drum, cleaning blade, and doctor blade (at minimum) need to be replaced for proper operation, and there is also a toner waste hopper that needs emptying or it will overflow on second cycle.
Just my 2 cents.
SOURCE: Reset Canon printer chip
you can override ink check status and manually reset it in drivers options
SOURCE: printer wont accept toner cartridge U150 error
do you use genuine canon replacement cartridge or OEM cartridge? if it is OEM or refilled one there is a problem however there is a trick to reset the cartridge chip,otherwise you cant use it.If it is an original canon it should not be a problem at all..Regards
