Question about Samsung HCN436W 43" Rear Projection Television
IC problem the three colors aren't coming together to form one clear object on the screen. How do I order a new Intergrated Convergance and where in the TV is it located?
  • 54 Answers
You can manualy set convergenge by going into the service menu. Save and its ok. If it is not, convergenge ic gone and you must replace it.
Posted on Dec 19, 2007
Service code
Its almost always a convergance inverter that has burned out. The IC chips as they are called aren't too cheap, Even the repair shop would suggest a new tv as a cheaper route in the long run. To make your set reliable again the convergance board needs to be rebuilt with all new chips, and pico fuses.
Oct 08, 2012 | Zenith R49W36 49" Rear Projection HDTV
I need to fix the wires on the coolent sencer for a 1997 mazda mpv.
Should be color coded. Put same colors together. If the factory plugs aren't available use wire connector kit. Comes with wire strippers and different connectors.
Sep 12, 2012 | 1997 Mazda MPV
Colors bend out on the left side of the screen and don't blend together. i think the projectors might be going out, but i'm not sure.
hello it sound like convergance chips ic 2 big black ic at the back of the tv connected to a metal frame called a heat sink they will need to be unsoldered also there may be resistor in front of the ic these will need to be tested and the 2 capacitor aswell. get a quote from an engineer
Feb 11, 2010 | Philips 50P8341 50" Rear Projection...
Blurry screen appears as 3d with blue discoloration
Go into the convergance mode and clear it up ,ther is also three knobs behind the press board one will adjust the overall background
color ,thew others focus.
Feb 08, 2009 | Hitachi 51F500 51" Rear Projection...
Mitsubishi VS-45609 Blue layer is distorted and seperated
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Dec 30, 2008 | Toshiba 55H70 55" Rear Projection...
Color convergance
THE akai convergence ic have proabaly blown. stk392's and will have to be replaced
Mar 18, 2008 | Akai PT5598HD 55" Rear Projection...
The Screen is giving me three images
Convergance ic bad.
· Samsung parts for convergance problem
Dec 15, 2007 | Samsung HCN4226W 42" Rear Projection...
Convergance adjustment
convergance amp ic bad
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Color misaligned in RCA P52927
Hi,sounds like the convergence power supply reg.has failed,when this ic fails the adj. projection tv leaves the menu,this ic is located on the board above the board with 6 heat sinks on it mounted on the black plastic,its the ic that is heawt sinked on this board,part number is 215530
Nov 06, 2007 | RCA P52926 52" Rear Projection Television
Samsung HCN436W 43" Rear Projection Television Logo
48 people viewed this question
Jerry Greenberg
Jerry Greenberg
