Panasonic Technics  SL-BD22D Turntable Logo
Posted on Jul 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Low volume after refitting belt on Technics SL-BS22B turnrable
I have just refitted the belt on my turntable that worked its way loose when I moved house. Now I can only hear volume at about quarter volume through the left speaker with nothing through the right speaker. I've checked the connections from turntable to amp and they seem ok. Full volume from all other units connected to amp.
Any advice appreciated.
Mike
Anonymous
Level 2:
Novelist:
  • Expert 133 Answers
  • Posted on Jul 14, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
133
Questions
0
Helped
73081
Points
344
Check also the wire connections on the pickup head, don't forget to check the connections for the same wires inside the turntable, see if you have a bad solder contact to the output terminals, also check the terminals themselves for any dirt/oxydation (i assume they are RCA's, and they DO loose contact if you plug them in and out a lot). Also check RCA's at the amp end.
good luck
3rq8 (Triarcuate)
1helpful
Why is the right side of my Technics turntable dropping out and giving me a ground hum?
It sounds like a bad connection to the cartridge, perhaps even the cartridge itself.
2answers
My player drags in turntable mode
It must be reseted. Try unplug power for ten minutes and replug. If no result check if you can remove its internal small battery and refit.
1helpful
Turntable is playing quiet
Hi, if your not plugged into your amp via a dedicated phiono input, Ie CD or Aux then you need a preamp to boost the line levels. Cheers john. Styluscity
Have a turntable not turning . model SL-20A
hi,
Check the belt of your turntable. If the belt get loose or broken this type of complaint can occur. Watch the following video. It will give you the information , how to remove and replace the belt.
ok
I had not used my turntable for about five years due to no needle. Found a needle and played two LPs, then on the third one, it just did not move or work at all. It lit up but just acted like it had no...
The low grinding noise could be the motor spinning with "no load" i.e the belt has snapped or fallen off due to being perished.
Lift the platter to refit the belt and or replace it if required.
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
1helpful
Where can I purchase a new rubber belt to drive my Servo Automatic turntable SL-B210 Ths is not an electronic belt
Here is a link for Technics Turntable replacement belts...just scroll way down the page for your SL-B210 belt listing $10.00. Hopes this helps.
http://www.turntablebasics.com/belts/technics.html
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Technic turntable SL-101
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES/c271_272_278/index.html
These guys are pros.
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
