Question about Gateway Computers & Internet
I have a Gateway E2100 and would like to install an upgraded video card. Can you reccomend a slimline PCI card that would work in this PC?
    Sergeant:
    Champion:
  • 242 Answers
EVGA Geforce 9400 512mb PCI - $70 and low profile ready so it should fit in your case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130499
Posted on Jul 28, 2009
Upgrade video card
check with gateway support to make sure your warranty is ok, for you change card, then goto motherboard manufacturer see if the card is supported
Jan 24, 2014 | Gateway SX2803-UB20P Desktop PDC 3.2GHz...
USB 3.0 upgrade
You might need to upgrade you graphics card.
USB 3.0 is the newest connection port upgrade, arriving on the market in 2010.
The cable port connection is far superior to the USB 2.0 port, as it is able to transport up to 5 gbps (gigabits per second), instead of the previous version's max speed of 480 mbps (megabits per second).
However, most computers do not yet have this connection port installed, in which case you are left to upgrade your own computer system to the newer, faster connection method.
Turn off your computer, then disconnect all of the cables running into the computer.
Remove the Phillips screws from the back side of the computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
This unlocks the case, allowing you access to the interior of the system.
Slide open the computer case.
Inside the middle is a longer circuit board.
This is the motherboard of the computer.
On the back side of the motherboard, facing the rear of the computer, are PCI card slots.
These allow you to install additional hardware onto the computer.
Slide the USB 3.0 connection port into one of the open PCI card slots, then push down the plastic levers along each side of the slot to lock the card into place.
Close the computer cover, then tighten the Phillips screws and reattach the cables.
Power on the computer, then insert the driver installation CD into the disc drive of the computer.
Once the installation wizard loads, follow the prompts of the wizard to install the drivers.
Restart the computer once finished and the USB 3.0 connection ports are ready for use.
http://www.pcworld.com/article/186566/usb_30_finally_arrives.html
Compatible graphics cards for Gateway Computers
Just as a processor handles data and a sound card outputs sound, your computer's video card is responsible for processing graphics and displaying them on your monitor.
The video cards manufacturers build into computers typically have enough power for the average user, but it may be necessary to upgrade your video card for better performance in games or graphics heavy applications.
Understand which types of video cards are compatible with your Gateway computer and learn about all your options.
PCI Express Graphics Cards
Many newer Gateway computers have a Peripheral Component Interconnect (PCI) Express slot in which you can add any PCI Express compatible video card.
These devices range from budget cards suitable for everyday tasks to high end models for gaming that cost hundreds of dollars.
AGP Graphics Cards
Older Gateway computers likely have an Accelerated Graphics Port (AGP) slot for AGP compatible cards.
The AGP bus provides sufficient bandwidth for high performance graphics cards, but the technology is no longer in use and AGP cards are difficult to find.
PCI Video Cards
Nearly all Gateway computers should have at least one PCI (Peripheral Component Interconnect) slot regardless of age.
This slot has enough bandwidth to support a wide range of peripherals like sound cards and modems, but is not suitable for high end video cards.
You can find a number of low and mid-range cards for PCI slot computers, however.
USB Video Cards
USB video cards are also compatible with Gateway computers sporting USB 2.0 or USB 3.0 ports.
These external cards sit outside the computer and allow you to connect additional monitors to your system.
They are a good option for people who feel uncomfortable working inside computers.
http://www.pcmag.com/article2/0,2817,2371083,00.asp
How to buy a video card
http://support.gateway.com/us/en/support/default.aspx
Gateway Support
Upgrade My Video Card on My Gateway Desktop
Gateway desktops are affordable computers, but they often do not come with top-of-the-line video cards.
Computer games may run slowly or not at all on your Gateway desktop.
One way to solve this problem is to upgrade the video card.
Video cards come in PCI, PCI-E and AGP interfaces, so you should be able to find a video card upgrade no matter what Gateway desktop model you have.
Click "Start" and right-click "My Computer."
Select "Properties" from the menu that appears.
Go to the "Hardware" tab.
Choose "Device Manager."
Click the plus sign next to the Device Manager entry listed "Display Adapters."
Find your graphics card in this list.
Double-click it.
Go to the "Drivers" tab and click "Uninstall Drivers."
Click "OK" to confirm the uninstallation process.
Shut your Gateway desktop down.
Pull the power cable out of the back.
Look at the back of the Gateway computer tower for screws on the right side panel or on top of the case for a cover release handle.
Nov 29, 2013 | Gateway DX4200-09 PC Desktop
E-6100 gateway
Hi David,
You mention that "it can't be a PCI Express" card.
If this is the case it means your motherboard takes the older AGP type of display card. Please confirm this with me. If however, your PC has a PCI express slot, there should me no limit as to how high up you can go in the range. The only consideration to take into account is your PC power supply. If you buy a powerful graphics card I reccomend that you have or buy a power supply of at least 500watts or higher.
Best wishes,
Graeme
Jan 12, 2012 | Computers & Internet
Can the wifi b/g be upgraded with the MIMO 3 802.11n Intel 5300 Wifi Wireless WLAN PCI-E Card? George
You can install that card on a gateway mx6025..
It wil work properly, just be sure to disable the onboard wireless card after you install the pci express card so they dont conflict..
Oct 30, 2009 | Gateway MX6025 Notebook
Change HP Pavilion Slimline s7520n Video Card?
The on-board RadeonXpress 200M graphics is a dog. It offloads a lot of work to your cpu, and shares system memory which ties up the bus and detracts from the memory available to the OS.
The s7520 suffers from thermal problems due to it's size and poor ventilation. It also has a very limted power supply. Therefore, your choices are also limited. If you could score Radeon X600 or X1300 with 128MB for cheap somewhere it would be a worthwhile upgrade. It does need to be PCI (not PCI-E) and half-height (low profile).
Jul 23, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Best video card upgrade for Gateway GT4024???? Stock computer....except ram upgrade to 2x1gb....want to increase the video handling from the slow onboard video
Your upgrade options for a better video card are really dependent on how much you want to spend.  You have a PCI express x16 slot which is what your are going to use.  Visit www.newegg.com and you can look up video cards by manufacturer, memory amount, and even filter it by how much you are willing to spend.  Here's a link at newegg for "the best video card upgrade":
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161203
Since there is a newer PCI 2.0 Express connection on newer computers, you can get your video cards cheaper now.  You will notice a huge improvement with any video card you choose since onboard video is about the worst.  Just remember to go into the device manager and disable onboard video card after you install the new video card.
Good Luck
Jun 10, 2009 | Gateway GT4024 PC Desktop
H Slimline New Graphic Card-No new DCI output-Yes old VGA output
you are missing nothing actually the graphic card over rides the onboard graphics and you have to use the graphic cards output ,only one hardware at a time for pci devices
May 08, 2009 | Computers & Internet
Upgrade video card
Any of the cards here are suitabl,e with almost all under $100 and are all PCI Express x 16
Your mobo is not suitable for the PCI X 2.0
Remember the amount of memory on the video card comes from your available ram - so you need to consider this when buying if you dont have much ram.
If you need more help deciding let me know
Apr 19, 2009 | Gateway GT5012 PC Desktop
Video card for the gateway 507gr
Yes, your computer specifically supports:
PCI Express 16x and
PCI Express 1x
The 16x is the long one and the 1x is the reallly short one. Most likely the card that you get will fit the big slot. Be careful not to upgrade too high though, because if you do you may have to upgrade your power supply as well. Ask someone at gateway or a local shop for a recommended card for your system.
Apr 23, 2008 | Gateway 507GR PC Desktop
Computers & Internet Logo
270 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
