Question about Frigidaire GLTR1670A Front Load Washer
Frigidaire front load washer problems
My frigidaire front load washer will not spin out and empty water on its last cycle. It hums through this cycle, then washers some more, timer goes off, and water does not empty out.
  • 8 more comments
  • Anonymous Dec 12, 2007
    I have the same problem. Thought that I might have over loaded washer, took some of the wet laundry out and started rinse cycle. Still won't spin.
  • Anonymous Jan 01, 2008
    I have the same problem. Any solutions yet?
  • nettiep Jan 08, 2008
    I'm having the exact same problem.
    1. I use HF detergent.
    2. Haven't checked the pump yet, but think that won't be the problem.
    3. Machine spins between wash and rinse cycle, just will not do a final spin.
    4. MFG book says check load distribution. Mine was OK.
    It also says it might not spin if the load is too light. That's not the problem with mine either. HELP! It's 3 months out of warranty and a service call is $95!!
    Annette
  • Anonymous Mar 05, 2008
    washer comes up without final spin
  • Anonymous Mar 09, 2008
    I just started having this problem today. The final spin is not working properly.
  • Anonymous Mar 16, 2014
    i have a frigidaire front load washer ftf2140fs1 that will wash then first spin cycle but not do the final spin cycle
  • Anonymous Mar 19, 2014
    displays error code 11, which indicates the pressure switch, however , I manually connect and disconnect the switch terminals, to simulate a fill and empty cycle . I'm assuming the switch is either on 0 ohms, or off, high resistance. So, can I assume the problem is in the motor control board?.th
  • Anonymous Mar 23, 2014
    Washer won't fill with water, only spins. I replaced the timer and same thing. Is there a reset button. I think I fixed this problem last time by pressing a reset button but can't recall where it is?
  • Anonymous Mar 26, 2014
    I'm getting code E40 on my frigidaire front load washer
  • Anonymous Mar 29, 2014
    When started my washer just changes to the no spin cycle then shuts off
Where is this screen filter? mine is washing and rinse but no fast spin or finale spin we had replaced all the mother boards and still have the problem. checked hoses nothing in there. motor is fine. no problems on trouble shoot mode . machine is 3 years old . dryer mother board went out after first year having it .was brand new . wont buy again crappy stuff... frigidaire.!!!!
Posted on May 21, 2008
We had the same thing!!!
I found out that there is a screen/filter on the front on the bottom that needs to be cleaqned out regularly!!!!!! now it works fine,it was loaded with stuff..
Posted on Mar 27, 2008
  • 125 Answers
Most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Posted on Jan 03, 2008
  • nothappy07 Jan 03, 2008
    sorry not solution .. clicked wrong place
Frigidaire Front load Washer Does not spin (Drains fine, Water comes in fine)
Hi John - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. The humming noise is mainly caused due to the drainage hose/pump possibly being clogged and needs to be cleaned. If not, the washer may be experiencing another possible issue with the faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 02, 2013 | Frigidaire FTF530FS Front Load Washer
My frigidaire LTF6700FSO will not spin
Your symptom sounds like a jammed drain pump. Was it spinning and then stopped before the spin cycle should have ended or did it not begin spinning when it should have?
Jan 17, 2013 | Frigidaire ATF6000ES Front Load Washer
My machine is barely draining water on the drain and spin cycle. It will spin but does not empty all the water out of the machine.
Hello - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if what pump out. Supposing that it does not, I would suggest contacting a professional to diagnose either the pump or timer.
Oct 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
On spin cycle makes hum and will not spin. I even emptyed it and it will spin but still makes a loud humming noise.
You have a loose or VERY warn drive belt.
If you can have someone place the washer on its front/face and inspect the drive belt, I am sure that you will see what I am saying.
The solution will be one of 2 things...
1. Find the tension control and repair/replace it
2. Replace the belt.
-Jim
Nov 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer runs fine until spin cycle--will not drain, though the drain pump motor hums. Also will not spin, which I assume is related to the fact that the tub is still full of water. If we manually empty the...
Hello, This is going to be one of 2 problems...either your drain filter is clogged or your pump is bad. Take off the lower panel on front, Behind this panel you will find what looks like a gas cap to a car. Unscrew this gas cap(have some towels handy to mop up water) remove the drain trap (filter) you should see alot of debris,coins maybe a sock blocking it...clean out the trap and replace. If this does not fix the problem replace the pump, although it sounds like it's humming it may be siezed or impellers might be broken. The pump should be located right next to the drain filter at the front of the machine. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Mike
Sep 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Nov 27, 2006 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLTR1670A Front Load Washer Logo
629 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
