Question about HP Color LaserJet 2600n Printer
Yellow not installed
I have two HP 2600N Printers. Both have had issues with yellow smearing to the page. You replace the Yellow toner and it will go for awhile and then start to smear again. One even gave a " Yellow not installed" message and will not print. Any suggestions.
Bruce
  • Bruce Weaver
    Bruce Weaver Jul 13, 2009
    Both were HP toners and I am trying make sue I can narrow this down. Maybe HV? Or can it be another connection?
  • Bruce Weaver
    Bruce Weaver Jul 17, 2009
    Thanks,
    I tried a test were on the printer that was showing yellow to the page I went and used a yellow that I know was good and it printed the first page fine. Then on the second page it showed a yellow over 3 inch square area on the lower right. The Third sheet was all yellow across the page. It still prints the DOC fine it just has a yellow over the printed DOC. I then put the toner back in the printer that I have that works fine and it printed with no problems.
    Bruce
    Bruce
    Genius:
  • 1,018 Answers
Are you using a factory new HP cartridge? If so, contact HP and request a warranty replacement of the toner cartridge.
Posted on Jul 13, 2009
  • Don  Farrell
    Don Farrell Jul 15, 2009
    Can you please answer my question. I need to know if I can factor out the toner or cartridge in use as the failure.
    If you are using Factory new cartridges then you need to move into the "service Call area.
    You may be fighting a defective toner sensor or defective motherboard, although that would be a stretch.
    But blown toner seals or seats is possible.
    Don
The logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
Aug 10, 2011 | HP Color LaserJet 2600n Printer
I have a HP Laserjet 2600N in my offie that is connected to the network. It is printing too much of yellow when printing any documents with colour. Please advise. Thank you
open the front where the cartridges, check if you notice runny yellow toner and toner surely you'll find under ', which replaces the yellow cartridge is probably refilat
May 25, 2011 | HP Color LaserJet 2600n Printer
I have a HP Colourjet 2600n which has worked well for 12 months plus. However it has just started printing with thick black smudges along the left of every page. It looks like there is yellow powder...
If you have BLACK Marks on the paper the YELLOW roller does not need to be cleaned usually.
To clean the yellow toner off the roller use a DRY lint free cloth. For this issue my suggestion for a resolution to the Yellow toner issue is replace the toner. They are not supposed to leak in the first place.
As for the BLACK tone on the left of the page you most likely have a Fuser issue causing that.
Jul 27, 2009 | HP Color LaserJet 2600n Printer
I have two HP 2600N printers that print Yellow onto the whole page. Replaced Toner and it wont and worked for a short time and then got worse with the yellow on the page. One of the units says yellow toner...
Generally this is a toner cartridge issue. Are you using genuine toner cartridges or generic remanufactured? I have attended alot of repairs on this model when clients use generic cartridges. Usually a genuine cartridge fixes the problem.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
Greyish marbeling on printed page & yellow wash allover page.
Sounds like you're probably running compatible cartridges. I sell a fair number of these cartridges to my customers, and it took a while to find a brand that actually worked. If you're seeing toner all over the place, the cartridges are most definitely the problem.
May 18, 2009 | HP Color LaserJet 2600n Printer
HP color laser 2550l prints only yellow
Are you sure that none of the other colours are empty? If they are then this could be the problem
Jan 01, 2009 | HP Color LaserJet 2600n Printer
My Hp LaserJet 2600n stop black stop printig
the problem is cyan and yellow toner are low, u will change the cyan and yellow it will be cleared otherwise the will be empty u can't print any thing suppose one will empty other cartridge will not work
Aug 26, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
164 people viewed this question
Seeker5211
Seeker5211
