Cars & Trucks Logo
Posted on Jul 13, 2009
Wont start 1995 bmw 525. just stopped on me pushed out of road day later it started and ran fine for 15 min. now it wont start unless it sits for a few days and is cool outside. when it starts last few min. not sur if its fuel or fire how do you check?
Anonymous
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 13 Answers
  • Posted on Jul 13, 2009
Anonymous
Contributor
Level 1:
Welcome Back:
Answers
13
Questions
0
Helped
3888
Points
34
Next time it wont start, spray some starter fluid into the air intake on the engine, if it fires then you have spark, if not.....prolly a spark issue.
1998 f250 5.4l would not start. changed feul pump and filter still would not start. 20 mni later started. was cleaning engine while running 10 15 min later died wont start.
Check fuel pressure at the injector rail. Could be your fuel pump relay is cutting out. If fuel pressure is good, check for sparks at the plug wires. Read the link below for more info.
Do It Yourself Diagnosis and Repair
1995 sl1
replace ignition coil
Okay my car started having problems starting it had a quarter gas tank and had never gave me any problems. Never has been over heated just had temp gauge replaced transmission flush and perfect inspection....
try my favorite simple fix. Get some stp fuel treatment or whatever is common for your area, read the label and make sure it removes water from the gas tank/gas pour the entire bottle in then fill up the tank. let the car run for a few minutes drive it if possible. Your problem should clear up shortly.
4answers
Car Won't run right and now not start
Check the gas it could be contaminated, Not to sould like a Wise guy but are you sude it 's not deisel fuel you put in.
1995 Chrysler Concorde
the alarm is activating when he locks it and for some reason the key or fob isnt deactivating it..check the disarm switches in the door
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
