Question about Dryers
Dryer is blowing cold air out vent and not drying clothes
    President:
  • 1,124 Answers
Could be the heating elliment..
One way to check --
remove the exauste hose..
Put a mirror to see into the exaust hole & try to see the elliment(s)..
When on - they glow hot like a stove burner..
If the elliment is not glowing - it needs replacing..
Hope this helps !!
Rate me good ;o)
Posted on Jul 13, 2009
Dryer tumbles,blows cold air no heat,looking for access to fuses,dont know what part of dryer fuses are located
Many times one pole of a double pole breaker may trip allowing the dryer to operate but with no heat. Go to the electric panel and reset the circuit breaker for the dryer. Also check to insure there is air flow at the vent a clogged vent willl prevent clothes from drying
Feb 26, 2011 | Dryers
Dryer is running longer than usual, it's tumbling,
no make listed here...I would pull the hose off the back of dryer and see if a lot of air is blowing out of vent. if not, heres your answer a clogged filter area ..if air blowing out leave vent hose off and dry clothes with vent off for one cycle. if clothes dry with vent hose off..you have a venting issue and need your vent cleaned out...
May 15, 2010 | Dryers
My tumble dryer is spinning and everything but my clothes are coming out cold and half dry, how can i solve this?
Clean the vent and make sure you have good air flow to the outside . You can disconnect the vent from the dryer and dry a load of clothes . Comes out dry , vent is the problem .
Jul 30, 2009 | Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
No heat
depending on the dryer there's either no flame or a blown heat element.
An appliance service person can fix this very easily.
May 10, 2009 | Dryers
Dryer
Disconnect the vent from the back of the dryer and dry a load unvented too make sure you don't have lint built up in the vent line causing an air flow restriction.
Jul 30, 2008 | Kenmore Dryers
DRYER WILL NOT GET CLOTHS DRY
A dryer needs only three things to dry clothes:
1. Tumble the clothes.
2. Blow the air.
3. Heat the air.
If your clothes aren't drying, you are missing one or more of these.
You've mentioned that the basket is tumbling. That's good. The blower is also running if the motor is turning. But that doesn't mean the air is blowing. It could be clogged up behind the lint screen, in the vent pipe behind the machine, or at the vent outside the house.
If it's blowing lots of cold air (go to the outside vent to find out) then your dryer isn't heating. This would mean some part inside the dryer has failed. If so, the first thing you want to determine is, does the ignitor glow? There's a hole at the very bottom front edge where you might see it glow. You may have to place a mirror in front of the hole to see it glow.
Write back with more symptoms, and I'll help you through the rest.
Mar 23, 2008 | Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
