Question about Maytag Washing Machines
Washer will agitate but does nothing through it's spin cycles. The timer advances through the spin cycle but you can't hear the motor run or even try to start, Washer is aout eight years old.
  • 583 Answers
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
as you mentioned timer advances,then check out cold water entering the machine or not. If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jul 13, 2009
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
Sep 18, 2016 | Kenmore Washing Machines
If it fills with water but won't wash, is it the timer
hi mary,i just wrote and asked you for the model number,if this is a regular top load washer it could be the timer as long as you don't hear the motor running,if you do hear the motor running you could have a broken motor coupling because the drain pump is on the motor shaft so it will drain,
http://www.youtube.com/watch?v=9K1KHEogf3c
if you don't hear the motor it could be the timer,when it should agitate try tapping on the timer and see if it works,it has points in it and they can get stuck together or burn out and have no contact like you're saying but it's just a guess without seeing it but if the timer is advancing through with no agitation it could be the timer,did you try any other cycles
Apr 02, 2013 | Washing Machines
It does not agitate when in the normal cycle and does not drain.
"Does not agitate" sounds like a broken or worn drive belt. "Does not drain" sounds like a broken or worn pump belt. Since it is unlikely that both belts are bad, I suspect that the next common link, the drive motor, is bad, i.e. your drive motor is either defective or not getting power during the agitate and spin cycles. The primary symptom for a non-operating drive motor should be obvious, i.e., the machine just doesn't run after the wash fill, and it doesn't empty when the timer advances to the spin/drain cycle. If the drive motor does sound like its running, I would then inspect both belts and drive motor pulley for proper operation.
Oct 04, 2009 | Maytag Dependable Clean Top Load Washer,...
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Will agitate; but won't go into rinse or spin - even if place the
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Washer fills,but when it tries to go into agitation cycle
if its not agitating on any cycle the you transmisson has went out ,,,,, if it does in some cycles but not others you have a bad timer
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
WASHER WON'T SPIN OR AGITATE
Fisher and Paykel pride 5.5. It is about 11 yrs old
Oct 04, 2008 | Washing Machines
Old Maytag model A510
I know this is an old post but, the most common reason this problem happens is because the timer fails to advance to the next cycle. There is a complicated escapement linkage between the timer motor and the timer cam inside the switch that likes to screw up. It usually burns off one of the sets of points so you can still have fill but no spin or fill and spin but no agitate. The most common set of points to burn off would probably be the set that relates to the spin cycle as the most amperage is flowing to the motor while under the strain of spin cycle. Remedy? Get a new timer switch probably about $50.00 American
Jun 21, 2008 | Washing Machines
Washing Machines Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
