Cars & Trucks Logo
A
Anonymous Posted on Nov 02, 2015
Does a 2011 caddyTDi250 1.6 ltr need the gearbox oil changed when the vehicle has its regular service?its 5 speed manual gearbox,and is there a filter to be changed?
Sean Piquet
Level 3:
  • Cars & Trucks Master 1,867 Answers
  • Posted on Nov 03, 2015
Sean  Piquet
Level 3:
Answers
1867
Questions
Helped
610722
Points
7259
No but check with the dealer or your service/owner manual for the manufacturer recommended gearbox oil change periods.
There is no filter on the manual gearbox .
Whatever the manufacturer recommended period is for a gearbox oil change, change the gearbox oil twice as frequently as recommended to maintain it in good condition. If, for example, a change every 50000 miles is stipulated then do it every 25000 or so.
5 Related Answers
Anonymous
  • 1665 Answers
  • Posted on Jun 12, 2008
SOURCE: Automatic gearbox
How to prevent the transmission from damage
(The filter usually is screen type and can be cleaned when remove bottom cover. but this is not to be done at regular maintenance inspection.)
- Regularly check your parking space for leaks. Doesn't matter, is it the engine oil leak, power steering fluid or transmission fluid; if you discover any, get it fixed before it caused something serious.
- Once in a while check the transmission fluid level and condition. Not all cars however have the automatic transmission dipstick, in some cars, for example, in late Volkswagen models, the transmission fluid can only be checked by the dealer. Consult with your owner's manual for details. If the transmission fluid level is too low, there is a leak somewhere that needs to be fixed.
- Change the fluid as often as it said in your owner's manual or when it becomes too dark (rather brown than red) or dirty.
Also, keep in mind that an automatic transmission can not be drained completely - there is always some transmission fluid left inside the transmission (the torque converter, in the valve body, etc.) which means you only can change about %60 of the fluid at once. This is one more reason to change it more often.
- Use only the same type of the transmission fluid as specified in the owner's manual or on the dipstick. Some vehicles (e.g Dodge Caravan) are very sensitive to fluid type
- Never shift to the Reverse or Parking until the car comes to a complete stop.
- Never shift from the Parking mode when engine rpm is higher than normal idle.
- Always hold a brakes down when shifting from Parking.
- The automatic transmission can be damaged if towing with the drive wheels on the road. Always use a dolly or place powered wheels on the towing platform (if the vehicle is front wheel drive - tow it from the front leaving rear wheels on the road.
the filter
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 01, 2009
SOURCE: auto gearbox service/oil change renault espace 3.0l automatic
if its working leave well alone,its a renault remember,topping up is done via the auto dip stick ,draining is done by slackening off the sump pan
Anonymous
  • Posted on Jan 26, 2009
SOURCE: Oil Change queries SUBARU IMPREZA RS 2.5 2005 MODEL non turbo
I am confused - I have a simple query and logged on to your site as you offered free advice! Do you not offer the service as described on your website. I definitely don't need a team of experts to answer my very simple question.
Regards
Vic Fenn
Anonymous
  • Posted on Aug 03, 2009
SOURCE: Motor Oil Type
My 1994 1.9L DOHC automatic requires 5W-30.
Anonymous
  • 854 Answers
  • Posted on Sep 10, 2009
SOURCE: how do i top up gearbox oil on suzuki alto?
Nissan 1400 Champ Bakkie. Easiest method how to refill the gearbox oil please?
Question edited for clarity.
Thread: Nissan 1400 Gearbox Oil
4x4 Community Forum https://www.4x4community.co.za > ... > Nissan
Apr 4, 2022 - The filler plug is probably on the lefthand side halfway between top an bottom. Its a square plug with tapered thread. If the oil on the gear ...
Nissan 1400 Service Help - 4x4 Community Forum
Apr 15, 2019
Nissan 1400 engine sump in an SJ410 - 4x4 Community Forum
Aug 31, 2011
Gearbox and Diff oil Help - Nissan - 4x4 Community Forum
Feb 11, 2014
Diff oils help? Dont believe them when the say they changed it.
Nov 5, 2010
More results from www.4x4community.co.za
How do you fill gearbox oil in a Nissan 1400?
WapCar https://www.wapcar.my > ... > BMW > BMW M4 Coupe
The filler hole is usually located at the correct height to fill the gearbox. So once it overflows.More The filler hole is usually located at the correct ...
1helpful
How to fill a sealed manual gearbox with oil
not referring to your particular vehicle such jobs are doable, just google HOW TO CHANGE OIL SEALED GEARBOX
Start by taking a look at tje link below
http://www.pistonheads.com/gassing/topic.asp?t=1036194
petrolheads seems to be a good website in regard to automotive queries
1helpful
Ck engine light on again..
Have your dealer look up this service bulletin.
NUMBER: 18-037-11
GROUP: Vehicle Performance
DATE: August 02, 2011
It states your PCM needs reprogrammed with the error code you are receiving P06DE. Was a pretty common problem back then.
2010 Touran 1.4 how often change the oil for the gearbox and what type and quantity of oil
VW 1.4i with manual gearbox 5 speed transmission:
1. Oil type: VW G50 & G51, full synthetic oil SAE 75 W 90
2. Gearbox refill = 1,9 litres
3. Filling plug location: Side of transmission
14helpful
2answers
2001 v5 vw golf auto gearbox oil change
THE 5 SPEED AUTOMATIC TRANSMISSION
At the bottom of the automatic gearbox (tiptronic) you will find one threaded plug on below surface, (follow red arrow in the picture below). This is for emptying.
The oil level threaded plug is placed on the car front lateral automatic gearbox surface, (follow yellow arrow in the picture below).
The filling oil plug is placed on the upper automatic gearbox surface, (follow green arrow in the picture below).
Automatic Transmission Fluid (ATF) checking:
1. Requirements for check:
1.1. Vehicle standing on level surface.
1.2. Transmission must not be in fail-safe mode.
1.3. Shift lever in "P" position, parking brake applied.
1.4. Engine idling.
1.5. Air Conditioner and heater OFF.
1.6. ATF temperature must not exceed 104 Fahrenheit degree (40 Celsius degree) at start of test.
1.7. Automatic gearbox oil capacity: 2,5 liter. Only ATF with VW designation may be used. Do not use any lubricant additives.
1.8. Automatic Transmission Fluid ATF - part number: VW G 052 990 A2
1.9. An ATF level check when transmission oil temperature is too low results in overfilling, when too high results in underfilling.
2. CAUTION: Too much or too little ATF will affect the operation of the transmission. The ATF level must be checked at regular intervals.
Don't forget to rate my response. Thanks!
3helpful
How much oil does a 1.4i 5 speed gearbox take?
Hi I have a 2004 Holden Barina CD 5 speed Manual. I am having trouble getting into First gear and changing up and down into second gear. The motor is running well, have car regularly serviced and this...
Hi threre.
Have no idea about the cost but check the oil in the gearbox and also make sure you put the right oil grade in. If the oil level is right you might have a problem with the syncro. The cost depends on the damage. Good luck
2helpful
2answers
How to check auto trans oil, 2003 jetta tdi
1.4. Engine idling.
What type of fluid do i put in my 87 doge ram 50.. tranny fluid needs to be changed it is a 5 speed manual
most manual gearboxes on cars of this age use ep90 gearbox oil.(NOT AUTO TRANS FLUID)
Automatic gearbox warning. Limited performance warning on Automatic transmission, one day it lights up the next day it does not. It says to contact service. Everything though is working fine, does it need...
always treat a warning message as serious and have it check at an accredited service center
could be that the oil needs replacing, a problem sensor or wiring or clutch/band adjustment
although there are manufacturers that say the oil never needs changing(GM for example), transmission oil suffers from extreme temperatures and loads and these factors cause oxidation of the oil (burning ) that requires the oil to be changed on a regular basis (60,000-100,000 miles or 100,000 klm
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
