Question about HP Color LaserJet 2600n Printer
My hp color laser jet2605dn has a brand new magenta ink cartridge yet does not print the red in pictures on my brochures
    Problem Solver:
  • 11 Answers
One solution is to make sure you have removed the orange plastic strip from the toner. The cartridges are sealed with a plastic strip when shipped and it needs to be removed from the toner side before installing.
Posted on Jul 13, 2009
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
No magenta printing
Dirty mirrors will gives you dull color images..It seems color combination faulty..
chk original cartridges installed? or refilled cartridges?
Take supply status page..
chk colors..If color is dull(light) clean laser scanner assembly mirrors.
Do the color calibration..
chk drivers.,
Print from other file..
May 09, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Ink clog between magenta cartridge and print head.
print head may be burned out try cleaning it then tap the cartridge and try a test page to see if it prints, if it still does not work try a new cartridge if that does not work then the print head is burned out, it may be under warranty you can go to www.hp.com and input your model and follow the trouble shooting guide and if you can't fix it you can register for free live chat help with the problem and it may be under warranty, many printers are having problems with this color cartridge drying up and causing problems not only hp but other brands as well. I suspect the pigment drys up but am not sure about it.
Feb 11, 2010 | HP OfficeJet Pro K8600 Printer
HP Photosmart 3210xi - some colors (magentas) will not print
Remove the magenta cartridge, and try cleaning the head with alcohol, maybe with a small paint brush or an acid brush. It sounds like ink has dried and plugged up that head.
Jun 04, 2017 | HP Photosmart 3210 All-In-One InkJet...
Prints "blue" on a document that supposed to be "red"
the red color contains the blue and magenta colors so your problem is not printing blue insted of red , your red laser miror is dirty from inside you should open the back of the printer then open the laser scaner then clean it then replace it
Jun 19, 2009 | HP COLOR LASERJET CP 3505 N PRINTER
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Serious Color Printer Issues
This is to do with the way in which the cyan, magenta, yellow and black ink is mixed to produce all the colours e.g. to print "red" requires both magenta and yellow ink. Thus, if the magenta ink is not flowing for some reason, for example, the "red" will print out as yellow. So, make sure all your cartridges and nozzles are working properly.
If you need further help with this, please post a new comment to this effect.
Oct 18, 2008 | Epson Stylus C62 InkJet Printer
F380
You are using HP's cartridge with the smallest output . So if you are printing 80 pages of text, you will have a problem by the time you reach 95 or 100 pages. If you are printing in color, you only have 1ml/color. Meaning 3 colors. But in order to print a red, it will combine a magenta and yellow to product 1 color. So 3 colors doesn't mean 3 ml worth of colors. Effectively you may only be able to print 10-20 pages of color then your cartridge is empty. The black cartridge has about 4-5ml of ink. So if you print a lot I suggest you get another printer.
Mar 30, 2008 | HP DeskJet F380 All-In-One Printer
Not printing magenta
Try cleaning contacts with a lint-free cloth or pencil rubber , touch the nozzle area with a cloth dampened with WATER, see if magenta appears. If nothing works, change cartridge...
Nov 07, 2007 | HP Deskjet 5440 InkJet Photo Printer
HP Color LaserJet 2600n Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
