Question about Toto Dartmouth 2pc. E/F Toilet CST754SF-01
Toto flush handle problem
I had the same problem and bent the rod slightly to solve the alignment problem. It is a bad design however and the handle pivot mechanism broke after 2 years. At $90 for replacement cost that's a real bad design. I would never by a toto toilet again.
  • 117 Answers
Did you try a new flapper? sometimes those are the reason they wont flush properly. check out the american standard cadet 3 it's half as much as a toto and works just as well
Posted on Jul 28, 2009
The dual flush push button flushing unit on my Toto cistren is not working
the connection rod under the lid is broken or not making the connection just lift the lift to see.
Oct 03, 2013 | Toto Aquia II Dual Flush Toilet
Toto toilet CT774S. The metal flush handle has fallen completely out of the tank. It's easy enough to slide it back in and push the metal rod into it inside the tank, but it isn't held securely in any way...
It appears that you are missing the nut that goes inside the tank. Look around inside the tank for it. If you do not find it, I suggest you take the lever to the nearest home center and try to find a replacement nut, or a cheap handle you can use the nut from. Most flush handle nuts are left-hand (reverse) threaded. I searched the internet for the part number for the flush handle assembly ( THU141#XX) and the price is nearly $70.00. Good Luck
Jan 06, 2011 | Toto Toilet Bowl Carrollton CT774S.51
HAve to hold the flush handle down for several
change and or adjust the flapper valve if the chain is to long flapper wont stay open long enough for the water to drain into the bowl
May 30, 2010 | Toto CST414M-11 Aquia Dual Flush Elongated...
Toto toilet ultra max flush
Open the tank and examine the linkages between the handle and the flapper. If the handle is sticking, it sounds like there may be either mineral buildup or a stuck chain.
May 27, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toto Dartmouth toilet flapper/chain design flaw
Your right this is a poor design. Space was the main reason for this and functionality was sacrificed. However, you can get a replacement rod at a major plumbing store. You could rig it by attaching a stem to the valve assembly. Allow the chain or rubber piece to slide over it. It is kind of like putting a permanent finger in the path of the chain to give it a "direct" lift up. This would then force the chain to go up instead of at an angle.
Jan 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Drivers side door, not opening
VERY common issue.. the handle being replaced is ok.. but the actual metal rod that connects it to the latch needs bent a little to make it more responsive, what happens is over time this rod (which is bent slightly) will straighten, and the operator pulls harder on the handle which eventually brakes.. then replacing the handle will solve it for a while, until the trend repeats itself... VERY common, I have fixed hundreds in the shop so far...
Jul 10, 2008 | 1999 GMC Suburban
Toto Dartmouth 2pc. E/F Toilet  CST754SF-01 Logo
750 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
