Question about Garmin StreetPilot c530 GPS Receiver
GPS wont turn on
My GPS went black and won't turn on. It seems like if I push the charger in really hard it starts to turn on then shuts down again. Any ideas?
    Brigadier General:
  • 4,090 Answers
Dont push it too hard you could dislodge it from the motherboard and then you miht as well throw it away! Cost 3 arms and 4 legs to fix.
replace the battery first and see if that helps as batteries can fade out after a year or two
Posted on Jul 25, 2009
Won't boot up. Error message "
did you try pluging into charger, my galaxy 2 if i run battery all the way down it wont do anything after it shuts down. at times i have had to plug in and wait sometimes 15-20 min before it will even flicker. hope it helps
Dec 31, 2012 | Cell Phones
I have a problem with my sony vaio!it seems to crush when i move the charger!its not shutting down but the scen is off and then i have to remove the charger so it shuts down and turn it on again!plus it...
It sounds like a loose connection in the charger cord or the AC jack. If the laptop is pulled by the cord it could have loosened/damaged the AC jack. If you remove the battery and only use the AC cord does the problem change? if you only use the battery and no AC cord does that change the problem? When Power is removed, without a proper shut down, the machine sees it as a crash therefore the disk check and black screen with boot options.
Nov 18, 2012 | Sony VAIO VGNBX740NS5 Notebook
My dell inspiron 1545 won't shut down went i click on the shut down icon it won't turn off .
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Jun 20, 2011 | Dell Inspiron 1545 Notebook
I push start button and hold this more than 2 seconds but the starting screen is not opening i also connect to battery charger from car and then pushing again to start but no reaction i have tomtom...
The issue could be a low power in the Tomtom and that is the reason it is not switching on. Now here the problem could be with the charging cable/wire from the car charger which might not be giving power to the GPS. Check for the fuse at the connector.
If the fuse is blown off the power wont goes into the GPS and it wont get charged and wont swich on. Look at the tip of the connector which has that spring like contact. You will be able to turn that to open it and find a fuse. Replace it with the right "amp" as the existing one. You will get one from Radioshack.
If you have already checked it and sure it is charging could be issue with Tomtom itself..Good luckKris..
Jun 18, 2011 | Tomtom ONE XL GPS
Garmin c530 powers up breifly then shuts down
The problem is with the battery, DC will not fully charge the battery to its required capicty to work. You need an AC charger and to charge it fully ( 10 hrs Max) and then try it. It needs a lot of power to drive the screen and connect to satellites.
Invest in an AC charger and all should work properly
Jun 07, 2009 | Garmin StreetPilot c530 GPS Receiver
The gps wont start
Have you checked the fuse in the charger?
Aug 28, 2008 | Digi MIO Walker 136 GPS Mobile Navigation
Garmin c550 GPS-Won't turn on at all.
could the battery be dead? Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset....
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
Sudden shut down
go to settings and go to initial setup, and click on master reset. the code is normaly 00000 or 12345
Aug 23, 2007 | Motorola Mobility RAZR V3
Tom Tom One Doesn't Turn on
in that case you will have to take off 4 screws on back the navigation system
easily take the back piece apart and unplug the battery wait couple a seconds then plug it back
it should work
Apr 20, 2007 | Tomtom ONE GPS Receiver
Garmin StreetPilot c530 GPS Receiver Logo
73 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
