Question about Blodgett Ovens
Have a zephaire GL when you first turn on the
Have a zephaire GL when you first turn on the oven it sparks the pilot lights then fades out and then the reset button comes on it will do this 10 times and then light and be ok it seems to do this all the time
"sparks pilot lights" , "reset button comes on" can you be more specific on these terms you used? I know this posting is an old posting, but I maybe be able to help you as I have fixed all the problems (multiple with 6 G-L's zephaire. Here I'll try to "assume" your terms. The g-l has one light at the front panel. If you mean it comes on and off (the light that is), this is the due to continuous try ignition module, not reading the "flame sensor input right", assuming there is no flame at the pilot. This might be caused by a mulfunction of the ignition module, or by a bad "flame sensor wire" or sensor. See if the pilot spark / flame comes on when you turn the oven on. See if the white wire coming out of it is good and not chewed by rats or something. If the ingition control (the blue box) is reading flame sensor input right, it will light the main burners, (red wire on the valve) if I recall correctly. The ignition control works properly on max 150 F and the ventilation fan on top if it's not working should be replaced. They sell them on line, and also grainger has it for around $32. The o modules go for around $129 to 170. and sometimes you find them on ebay for around 50. Hope this helps.
H
Posted on Oct 14, 2009
I have a blodgett zephaire gl oven. unit kept buring up 24v transformer, was old bad centrifical switch in motor. I replaced motor with brand new one, unit still buring up 24v transformer.....why ?
A short somewhere causing it to overamp. Put a 3amp inline fuse on the secondary side (24v side) on the hot wire. This will save the transformer and blow the fuse not the transformer. The centrifugal switch prolly wasn't bad. So I would trace the wire coming off transformer and look for bare wire or loose wires. Anything that would cause a short
May 04, 2016 | Blodgett Ovens
What are the possible sources of the following problem? Our convection oven works fine when it's turned on in the morning. However, when you open the doors for too long, the fan needs a manual push
The oven is designed to turn off the fan if the door is left open too long. I think it is a protection to avoid injury to the user due to heat circulation. It might be best to turn down the heat setting when opening the oven for long periods whilst the cooking is on. If you want the manual it can be downloaded from this site. see page 23.
http://www.blodgett.com/wp-content/uploads/Zephaire-100-G-200-G-ES-man-english.pdf
Aug 26, 2014 | Blodgett ZEPHAIRE G SGL Gas Single Oven
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Jan 05, 2010 | Magic Chef Ovens
I have a Blodgette/Zephaire Convection Oven. I need a part# for a conversion kit from nat gas to propane. Model# Zephaire-G-L.
I went online to the Blodgette Company. I went to service request and asked the same question. I recieved an answer via e-mail, the items and part numbers need. I then contacted a local distributor for the items needed.
Oct 09, 2009 | Blodgett (ZEPHAIREG-DOUB) Double Oven
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
Sep 07, 2009 | Kenmore 30169 Electric Single Oven
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Ovens Logo
240 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Dan Webster
Dan Webster
joneable
Level 1 Expert
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
