If your 2004 Impala has 16" wheels on it...these are a perfect fit for your Impala suspension, and tire clearance and performance...you can read the sidewall tire size on your car to confirm the 16" wheel size...the tire will read just like your replacement tire 225/65/16...many came with these...I will check factory specs if you will respond...Thanks.
The stock wheels are 16"...:)
Yes Thank you.
This tire size is perfect for your Impala...now standard size on newer models too...:)
SOURCE: Optional tire size for Honda Odyssey EX 2004
yes you can use the tires of your choice as long as they are 16 inch tires
SOURCE: 2004 TrailBlazer: what size tire fits a 2004 chevy trail blazer...
Typically it is a 255/65R/17 or 255/70R/17
SOURCE: will 265/75 r16 tires fit on 2000 chevy silverado
only problem may be the lower corners of the bumper plastic may touch on hard turns . it can be trimmed easily
Thank you so much.
