Question about Dishwashers
No water spraying and there is water going to the dishwasher
  • 6,784 Answers
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Posted on Jul 13, 2009
Spray arms not working
Hi frustrated in Raleigh,
I understand that the spray arms are not moving or spraying water, even after you have cleaned the screens and arms. What might be happening is you are not getting enough water pressure to the dishwasher.
The hot water line to your dishwasher must provide water pressure between 20 and 120 psi.
Low water pressure may occur when laundry or showers are in operation.
Wait until water use is reduced before starting dishwasher.
If you are still noticing that the spray arms are not moving or spraying water, I would have a local Authorized Technician come out to see what exactly is going on with the spray arms of your dishwasher.
-Best Regards-
Jan 06, 2014 | Frigidaire FPHD2491KF Dishwasher
Gritty film left on almost all dishes, rinse aid level seems to always remain at full, but apparently not rinsing well.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Mar 11, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Water doesn't come out of spray bar. water fills dishwasher (and can drain), it also gets heated. But the spray bars won't spray any water (top or bottom). Any ideas?
There is a pump that sends the water to the spray bars. I believe it is broken. Perhaps there is a jam but I don't think it is possible because the water is filtered before going to the pump.
Anyway. The pump may need to be replaced (not the drain pump).
Sep 01, 2009 | Kenmore Dishwashers
Dishwasher top spray bar does not spray due to low water fill
Check the water hose going from the sink to the dishwasher to make sure it is'nt clogged, if there's a water shut off valve under the sink make sure it's fully open, also check to make sure the spray arms at the bottom of the dishwasher that supply water to the top rack is clean with no debris or obstructions in the spray hole's, the water entering the dishwasher should be at a warm temp, if it's cold the dishes will not get clean, you should have good water pressure from the house supply for it to fill properly, the float is also called a flood switch, it should not be activated during the water fill cycle, if it's activated it will shut off the water inlet valve and the wash cycle will stop or the dishwasher will drain, if your still having wash problems it could be a defective water inlet valve or a bad timer, if that's the case you might have to call an appliance repair man, hope this helps, good luck.
Mar 28, 2009 | Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water not going through spray arms
possible you have a leak and the bottom tray has water in it. tilt the machine back to 45deg and see if water runs out of the back. if it does, after putting upright, the machine will work - then find the leak!!
May 05, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Water not going in
This is a little late for the OP. But, I had the same problem over Thanksgiving of 2008. I searched online and saw that other people had the same problem, but there were no solutions posted. So, I paid $130 for a service tech to come fix the problem - maybe this will save you some time and money.
The solution was simple...pour boiling water (I boiled about a half gallon of water in a cooking pot) straight into the pump where the water sprays out of. You don't have to pull your dishwasher out and no tools are needed. Just open the door, pull out the lower roller tray, remove the bottom spray fin (just pull straight up), and pour the boiling water straight into the hole where the bottom spray fin was attached to. Next, put everything back in place, push the Power switch on, select a wash mode, and close the door. The dishwasher should start spraying water inside as usual.
The service tech told me that there are only two pumps in this dishwasher...one to pump the water in (the one that had the problem) and one to pump the water out. When you don't use the dishwasher frequently, the seal in the wash pump seizes up (sticks together). You can hear the motor humming, but the pump isn't able to send the water up into the spray fins. By pouring boiling water into the pump, it helps to break that stickiness and allows the pump to start sending water up into the spray fins. The solution is to run your dishwasher at least once a week. Even if you don't have much to wash, run a rinse cycle to let all the parts move and stay loose.
One other tip the tech told me is to pour a cup of white vinegar into the pump when you go away on vacation and the dishwasher won't be used for a week or more. This should keep the seals from sticking together. I haven't tried this yet.
Hope this helps.
Feb 20, 2008 | Bosch SHU9915UC Dishwasher
Dishwasher
Plugged filter or spray arms .
Sep 30, 2017 | Dishwashers
Dishwasher pump will drain but not force water into spray arms
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Dec 11, 2007 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
