Question about Akai PDP-5016H 50 in. HD-Ready Plasma Television
Picture and audio gone, loud cooling fans
Akia 50" flat screen plasma. Model # PDP5016H.
picture and audio gone. Also loud cooling fan or fans
  • 1 more comment
  • aireserv_1 Jul 13, 2009
    How much for a circuit board? I'm a repair technician in the H.V.A.C. field, is this something I maybe able to replace myself?
    I replyed about an hour ago, How much for a circuit board and with my experience as a service techinian in the hvac field I believe I could replace the board. Please reply as to the cost and level of difficulty in changing the board. The T.V. is only 4 years old. I would hate to throw away a T.V. I paid $3000.00 less then 4 years ago.
    Thank you for your quick reply.
    Steve
  • aireserv_1 Jul 14, 2009
    I just noticed how to find the reply to my request for a reply. However on another posting on this site the same Akai flat screen the FixYa tech writes he can sell the board for $250.00. Why such a differents?
    President:
  • 2,777 Answers
Sir you should probably check with an independent dealer rather then try to buy a part from one of the experts on this site. Make sure you deal with a real company so that if you need to return something you can. $200 - 300 should be the range for the board in question. Be careful of dealing with individuals.
THanks
Tim
Posted on Jul 15, 2009
  • 583 Answers
The board should cost approx 750 dollars and if you are familiar,replacing the board will be easy.you can also request the istruction chart while ordering the new circuit which usually comes free with circuit board.
Please do rate the solution. Thank you for using fixya.keep updated. thanks
Posted on Jul 14, 2009
    Top Expert:
  • Akai Master
  • 79,865 Answers
U HAVE A SHORTED MAIN CIRCUIT BOARD HIGH VOLTAGE SECTION, TIME TO REPLACE THE TV OR CALL A REPAIR PERSON.
Posted on Jul 13, 2009
Very noisy fan on a Zenith 50" Plasma (Model 50PC3DB-UE). Should I replace the power supply or just a fan?
if it has only one fan, replace that but look to see if fan dusty or not.
I have seen ones with two identical fans and one made noise and the other did not, swapped them and then knew for sure which was the bad one, in that case better to replace both fans at same time.
Dec 19, 2012 | Zenith Z50P3 50 in. Plasma TV
Loud fan...how difficult to replace
yes the fan should be available from www.tvrepairworld.com just hit the contact us button on the right side of the page for assistance. They can also provide instructions on replacing the fan.
Jan 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Heard a loud Popping/snapping sound, and the screen went black. The unit still has power and audio but no picture at all. I looked at all the capacitors and they appear to be in good shape. 75$ just to...
Possibly ZSUS or YSUS boards are gone for this kind of problem, please check at shopjimmy.com for required boards and new lcd tv is rather better than repairing this plasma tv.
Thanks.
Apr 26, 2011 | LG 50PC1DR 50 in. Plasma HDTV
My screen went out on my 50'' nak ...how much to replace it
If your diagnosis is correct and you have a broken plasma screen unit then it's beyond economic repair as a new panel costs more to supply and fit than buying a complete replacement tv.
If the tv has simply gone into protection mode due to a failed cooling fan or if a transformer, relay or circuit board has failed then it's normally a straightforward and cost effective repair but definitely not a DIY job. Fans and relays are the cheapest repairs, typically labour for one hour plus the (usually) cheap parts, transformers and circuit boards are typically one to two hours labour but the parts can be very expensive but the total repair is typically far less than the cost of another 50" plasma tv.
Nov 11, 2009 | Nakamichi Televison & Video
Have a 50 inch LG plasma tv and it has developed a loud fan like noise coming from it
Hello. Most plasma's do have internal fans that keep the temp down on the internal components. Maybe you have not noticed it if the tv volume was turned up. It also could be that tone of the fans are defective, which would cause them to sound louder. If it is unusually loud, you might want to have the t.v. checked. I hope this helps. Don't forget to rate me if I helped you. take care. Ron
Sep 08, 2009 | LG 50PX5D 50 in. Plasma HDTV
My 50 Viore dlp tv turns itself off after just a
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Jul 20, 2009 | Televison & Video
42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
PDP5016H AKAI Plasma TV
Try PTS Electronics 800-844-7871.
Scott,
Aug 16, 2008 | Pioneer PDP5016HD 50 in. Plasma Television
Akia PDP5016h no sound
replace the speakers my friend. you had probably turned on the speakers so loudly that the lead inside the speaker got loose thats why its faulty now.
Apr 15, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Open Questions:
See all Akai PDP-5016H 50 in. HD-Ready Plasma Television Questions
Akai PDP-5016H 50 in. HD-Ready Plasma Television Logo
157 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
