Question about KitchenAid KSCS25IN Side by Side Refrigerator
Ice Maker problem
I have a kitchenaid side by side refrigerator, the ice maker hooper is in the door, the ice maker suddenly just stopped rotating the ice out of the icemaker compartment, I have removed the ice maker thawed it out and reinstalled, after a while it filled with water, froze, the flipper moved down and just stopped????? It will not push the ice out.
  • 2 more comments
  • Anonymous Dec 16, 2007
    i have the sam exact problem, the fridge is just 2 years old.
    i wll call kitchen aid tomorrow
  • budgaither Dec 28, 2007
    The problem is that the water supply freezes and no water can come in to the ice maker. I have turned the fridge off and that thaws the ice in the tube, but I don't want to have to do that all the time. At the moment, I have lowered the temperature in the freezer compartment by 5, maybe that will work. Please, if anyone has any other suggestions, they're welcome.
  • GEG14 Oct 02, 2008
    My KCS25IN does not rotate the ice and does not dispense the ice out from the door. I started having this problem after my power went out and the refrig/freezer did not run for 3 days. The light is still lit on the outside of the freezer and the water still comes out of its dispenser, I'm only having problems with the motor that turns the cubes.
    HELP
  • STEVE Jul 19, 2013
    there is a heating core inside of the icemaker...it losens up the ice once they are made so the maker can turn and push into try...thats the problem...i had the same thing...they changed the icemaker out
Well here it is, the shaft that turns the teeth to free the ice cubes is made of plastic, and once I took it all apart, which is easy to do why the way, I saw that the shaft was broken. A quick trip to a Sears parts center, had the same ice maker costs about 150.00, same cheap plastic shaft, but fixed the problem lickety split.
Posted on Mar 17, 2008
When our icemaker has not worked, I used an electric hair dryer and heated the ice maker components. It has worked in the past. I saw it suggested in the manuel. It resolved the problem for a long time, but today it has happened again, so will see.
Posted on Mar 15, 2008
Apparently lowering the temperature by 5 degrees in the freezer compartment will keep the input water tube from freezing. It is working fine now!
Posted on Dec 29, 2007
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker all of a sudden stopped working.
Remove the ice bucket and look for ice hung in the fingers. Use a hair dryer to melt a jammed ice cube. Keep at it till the fingers move free and advance to the next harvest cycle. If the ice mold is empty replace the water valve. If the ice mold is full replace the ice maker.
Aug 24, 2011 | KitchenAid Superba Architect KSCS25INSS...
Our kitchenaid side by side refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 06, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
Ice maker not working
heatman101
ghdh
Jan 08, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSCS25IN Side by Side Refrigerator Logo
304 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
