Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Mower starts and then after a few minutes it starts to sputter then shuts off. Changed the spark plug and it still does it.
    Problem Solver:
  • 12 Answers
Check the fuel cap to see if the vent is clear . the gas is displaced by air so if the vent in the cap is clogged with dirt . we have no dis placement of fuel.
Posted on Aug 09, 2009
  • don c Aug 19, 2009
    Also check the solenoid on the bottom of the carburetor. Quick and easy way to check for this is When the motor stops remove the air cleaner cover and filters. Use starting fluid or brake clean and spray some in the carburetor opening then try starting it . if it starts then the solenoid is bad. only after trying the cap thing.
  • 279 Answers
Check fuel filter and air filter
Posted on Jul 14, 2009
Was mowing the lawn about 20 minutes then mower stopped. It is a craftsman platinum 7.25
sounds like the spark plug may be fouled or the fuel filter or carburetor is dirty.
Sep 17, 2016 | Craftsman Garden
Not getting any spark
Clean the Plug and replace the Seafoam gas with fresh. Althiough the Seafoam is a cleaning agent, it cuts back on the gasolines octane and it can slightly foul plugs.
Aug 07, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Mower been in the shed foer winter,2yr old model wont start,checked the spark plug,fuel,carb checked all moving parts,still only sputters when pulling cable to start
flooded????,,turn off petrol, take out spark plug,,give a few pulls then replace plug turn on fuel and give it a try,,cheers,hope this helps.
Feb 27, 2011 | Troy Bilt 5.5hp Self Propelled Mower
My mower starts when cold and runs for a while OK
it sounds like the ignition coil is shorting out inside once it gets hot. or it could be the spark plug as well.
May 01, 2010 | Toro Lawn Mower With Toro Power Tools
Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Aug 23, 2009 | Garden
The lawn mower starts and then sputters and shuts off. Checked air filter - it's clean, changed gas, checked oil and spark plug. After changing gas it stays on a few minutes longer but sounds like it will...
Sounds like you have a carb problem here. If your not familiar with the carb have someone qualified to do it. Other wise it sounds like the jet in the carb has dirt in it, obstructing the gas passage. Most of those jets are directly in the bottom of the carburetor. Remove it and be careful not to drop the bowl because if you do you could cause the float to move and that could get stuck and then not shut the fuel flow off to the bowl when re installed. Good luck
Aug 02, 2009 | Garden
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
375 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
