Question about Samsung AW0603B Air Conditioner
Do you fill the high or low pressure valve - Samsung AW0603B Air Conditioner
  • 1,543 Answers
I use a heated charging cylinder to fill the high pressure valve, but you shouldn't mess with the sealed system if you don't know what you are doing. (ie: should be certified to work on sealed sytems, and thus know how to recover and evacuate a system, and then charge it properly. It's not a do it yourself project.)
Posted on Jul 13, 2009
Toilet is working perfect, fills to correct level, but it takes a long time to fill after flushing. It is not leaking out
Either...
Low water pressure.
The inlet valve isn't opening fully.
Small bore pipework.
Is the water pressure good in the rest of the property?
Is so then there may be an isolation valve on the toilet which isn't fully open.
Apr 13, 2017 | Home
How and where to add freon to a1995 sedan deville
Verify ambient temperature is above 65 degrees F.
1. Safety> - safety glasses, long sleeves and gloves, (exposure to refrigerant can cause frostbite).
2. Attach hoses to manifold> assembly, (hi, lo, and fill).
3. Remove caps from service ports, (Low press. Larger tube from evaporator to accumulator - passenger side over fender well; High Pressure - smaller tube from evaporator along firewall towards driver's side). Verify service> ports are clean.
4. Attach low press. and high press hoses to proper service ports.
5. Start car>, reset low refrig code, and turn ac on high and fan on high.
6. Read gauges and compare with chart provided with gauge set.
7. If low and high press readings are both low, then system needs recharge.
8. To recharge, attach fill hose to can of R134a and slowly open low press valve>, (NOT HIGH PRESS VALVE), until low press side reads 40 psi.
9. When flow stops and pressures stabilize close valves> and disconnect manifold from service ports and refrigerant can. Replace service port caps.
Aug 19, 2015 | 1995 Cadillac DeVille
My Whirlpool Front Load washing machine "sings" during addition of water during some portions of the cycle. In other words, when adding water to the machine, a high-pitched sound is produced...
The chances are that this is one of the rubbers in the inley valve vibrating at a high frequency as water rushes past it. Usually the result of high water pressure, though occasionally low pressure (But I would expect you to describe that as a low humm, so lets presume the pressure is a bit high).
Your machine may be cold fill only or hot AND cold fill. The chances are highest that the COLD feed is the issue (Hot water is usually at a lower pressure) so start there.
Try reducing the pressure to the feed, if you have no specific way of doing this, then simply go to the isolator valve where the feed pipe to the machine meets the plumbing and slowly turn it off. as you turn the lever on the valve, the noise will probably reduce long before you have actually isolated the water supply completely. Leave the isolator valve lever in that position.
Jul 19, 2011 | Washing Machines
I have a 1995 jeep grand cherokee and i cant figure out the difference between the high and low side is the low side gonna be on a metal pipe near the fire wall or on the compresure its self cause that is...
during the 1995 R12 was still in uses if you have 134a then you have the conversion here are the valve rule of thumb if the A/C pipes are thick you have the low pressure line the filter drier is a low pressure area, here the high pressure the condensor the thin line is the high pressure, go to the filter drier follow the thick line and you will find a valve that low pressure, go to the condensor the thin line you may even find a sight glass that area is the high pressure you should find a valve this is the high pressure
Jun 04, 2011 | 1995 Jeep Grand Cherokee
Where do I charge r134 coolant? the adapter on can fits the high pressure valve and the low pressure valve is too big? please help..
can't be.the larger port is the HP side, and the hose on your can will only fit the low (small) pressure side-you CAN fill a system on the HP side, engine off, by hooking up to the HP side and inverting the can so that liquid 134a fills the high side-but it is not recommended if you do not have manifold gauges and aren't experienced with AC systems.
May 31, 2011 | 1998 Toyota Corolla
Recharge a/c i have r12 which valve do iuse black or red
line that goes to compressor is low side line out of compressor is high side
always fill on low side
also r12 hase been band for sevral years and should not be used
if this freon is r-12 conpatible or replacment then your fine
after leak been repaired and system pressurized and vacumed out
start engine put a/c to max blower motor to hi open windows
conect your fill bottle to low side open valve and system will start filling
when freon reach enougt pressure the compressor should start and draw in
the freon if it fails to start you could jump the low pressure swich to help draw in
freon when system has drawned its capacity shut off your bottle and disconect your line to fill
cap off the valve
if compressor fail to start you have another issus could be electrical
take CAUTION doing repairs to a/c system
Apr 02, 2011 | 1989 Toyota Camry
My machine fills with water even when it is not plugged in
The machine relies on water pressure to close the valve when not in use. In low pressure areas, this doesn't happen. Change the valve and take out the high pressure limiter (in the valve itself, looks like a small thimble of mesh)
Mar 19, 2011 | Tricity Bendix AW1000W Front Load Washer
How do I fix a Air condition blow out hot air?
Go to your local auto parts purchase a a/c charge kit for about $69.00, find the low pressure(suction) fill port, there are two ports in every a/c system one is a low pressure side used primarily to fill a system with freon 123a or the like and it is the larger valve mounted on the line, then there is the dangerous high side valve, this is a smaller diameter valve mounted to a smaller diamet a/c line, this is under extreme pressure so donot attempt to fill this high side with freon as it can backfire on you and cause injury.
The low side fill kit will not fit on the high side port so thank godness for that.
start the vehicle put the a/c on full cold high blow fan speed, start filling the low side with a can of 123a freon+oil additive, which equals one pound of freon and check the inside a/c vents, getting cold? If its perfect then you are done, the system may have a very small slow leak and if it only takes a one pound can to fill it once or twice a year you are ok, if it takes more you may want to add a second pound can of freon 134a containing a dye additive that will work its way into the system and show you where the leaks are by exposing a color once it hits the air coming out of the systems defective seals etc.,also they sell a sealer + freon one pound can that can be used to try to fix the leak without having to get too expensive on the repairs.
A car's air conditioning system only hold like 2 3/4 pounds of freon, so in the event you happen to over fill the system a high pressure blow valve usually mounted on the a/c compressor will purge off the excess, but let me warn you they blow off without any warning and can startle you. Always think safety first, wear protective equipment. Work Smart, Work Safe.
Happy Motoring!!!
May 20, 2010 | 2002 Ford Escort
Where is the low pressure port to fill ac
The low pressure port should be on the Accumulator, that's the silver cylinder that has the low side A/C line going in to it. You'll see the valve on the cylinder for you to add the R134a, do not aver fill the system. Safest way is to open and close the refill valve and let the A/C run for 2 min and see who cold the system is getting adding little at a time. To much R134a in the system will also give you poor A/C performance, to high of pressure in the system will shut down the compressor also.
Thank you for using fixya and when you think the air coming out of the vent is cold enough, stop charging the system.
Jun 02, 2010 | 1997 Chevrolet Lumina
Samsung AW0603B Air Conditioner Logo
89 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
