Question about Hobart A200 Stand Mixer
Hobart A200 The agitators are scraping on the bowl. How do you correct this?
  • 640 Answers
Make sure the planetary bolt (the bolt that sits next to the shaft is tight and all the way up,let me know i work for hobart and repair these units.
Posted on Nov 30, 2007
Where can i buy a splash guard for hobart A200
There are two different splash guards fort he A200.
If you have a 12 quart bowl the splash guard is a part number 438078 and if you have the 20 quart bowl the part number is 438079.
Both parts are available from
http://storefront.whaleyfoodservice.com/.
Jun 21, 2012 | Hobart A200 Stand Mixer
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
How to adjust bowl height on 20 qu hobart mixer.It is an old A200 1/3 hp Paddle is to high in bowl and will not mix dough on bottom and sides of bowl
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
Dec 12, 2009 | Hobart A200 Stand Mixer
How can i tell the which size my mixer is?
A 200 means 20 quart. I assume you have no bowl or else you can just measure the volume of the bowl.
Nov 29, 2009 | Hobart A200 Stand Mixer
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
Hobart A-200 mixer (OLD!) runs hot & shuts down.
You have killed it by overloading the bowl. Hobart recomends no more than 65% bowl capacity on doughs & 75% on batters or icings. Replace the motor or the whole unit
May 25, 2009 | Hobart A200 Stand Mixer
Bowl won't stay up
Hi. Goto www.hobartservice.com and register for free.
Search for your mixer model in the Discontinued Products area.
Download file# F6731.pdf On page 4 find the drawing labled PL 2523 If your reassembly geometry doesn't match that of the drawing, you must correct it. If this solution has assisted you please rate it. Good luck!
ricardok45
Mar 22, 2009 | Hobart A200 Stand Mixer
Hobart A200 oil leak
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Sep 10, 2008 | Hobart A200 Stand Mixer
Need cast iron bowl holder assembly for Hobart A-200
if your looking for the bowl yoke goto hobartcorp.com or call 18884hobart for the part number and price.
Dec 30, 2007 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
147 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
