Could be a number of thing's ! Testing the electrical circuit is the way to find out what's wrong . Using a wiring diagram and a DVOM - digital volt ohm meter . Videos on youtube showing how to test it ! Without testing i would only be guessing . Does it work in high speed ? In high speed it by-passes the resistor . If it doesn't work in any speed more then likely the blower motor is the problem !
Air Speed
The HVAC control assembly applies ground to the blower motor control circuit that corresponds to the selected blower speed. The resistors and the blower motor are in a series circuit. The following list represents the number of resistors in series with the blower motor per particular speed request:
• Low speed--3 resistors
• Medium 1 speed--2 resistors
• Medium 2 speed--1 resistor
When the operator requests High speed, the HVAC control assembly applies ground directly to the blower motor through the high blower motor control circuit. The resistor card has a fusible link which, if blown, will require that the card be replaced.
It may have a controller that has failed. The system may not work if the blower is dead. There are a dozen or more components involved. You'll need someone to check and see if the blower motor is getting voltage and go from there.
Do the blower speed settings still work, just weaker? Or is it just one low speed all the time? If you can still change the speeds then it's a weak blower motor. If its just one low speed all the time, (same speed for high and low blower speed settings) then you need a blower motor resistor.
fix the idle speed to 850-900 rpm
check the alternator and voltage regulator as the voltage should read 14.5-14.8 volts dc at 1000rpm or higher regardless of what is running
have it bench tested by an accredited auto electrician
