Garden Logo
Raphael Carey Posted on Nov 02, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can you add a ignition chip to a 55cc timber bear
Ignition coil went out . Can a ignition chip be added to replace firing. Or do I have to order the original ignition coil.
Bill Boyd
Level 3:
Top Expert:
  • McCulloch Master 53,816 Answers
  • Posted on Nov 02, 2015
Bill Boyd
McCulloch Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11947825
Points
172802
Probably have to order the coil from the manufacturer or an authorized service agent
1helpful
Need firing order for 3.8 v6 motor-1987 buick
  • Type I ignition coil (all coils on 1 pack)
  • Type II ignition (coils can be replaced separately and wires on same side of coil pack) Which firing order pic depends on the v
  • Or
  • Regards,
  • Tony
Jun 23, 2011 • GPS
3helpful
2answers
Diagram for 3.8 firing order
1987 Pontiac Bonneville 3.8 liter V-6 VIN "3"
Identifying Ignition Types I and II
On Type I coil packs, three twin tower ignition coils are combined into a single coil pack unit.
On Type II coil packs, the coils can be replaced separately and the ignition wires are all on the same side of the coil pack.
With Type I Ignition
With Type II Ignition
Hope this helps.
4helpful
2answers
How do Iknow fireing order on ignition coils?Idon't know coil order
Here ya go...found the block for the reply....
3.8L engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
7helpful
2answers
Spark plug diagram
Several engines here:
* 1.8L (B18B1 and B18C1) Engines Firing order: 1-3-4-2 Distributor rotation: Clockwise
2.2L (F22B1) and 2.3L (F23A1) Engines Firing order: 1-3-4-2 Distributor rotation: Clockwise
2.5L (G25A4) Engine Firing order: 1-2-4-5-3 Distributorless ignition system
3.0L (C30A1) Engine Firing order: 1-4-2-5-3-6 Distributorless ignition system (one coil per cylinder)
* 3.0L (J30A1) Engine Firing order: 1-4-2-5-3-6 Distributor rotation: Counterclockwise
3.2L and 3.5L Engines Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Hope helped with this (remember rated this help) Good luck.
8helpful
2answers
Need firing order and, I need to know what side the number one piston is on?
To avoid confusion, remove and tag the spark plug wires one at a time, for replacement.
The 3.5L (VIN H) engine's unique ignition system has the ignition coils directly over each plug. No spark plug wires are used.
If a coil is replaced on any of the 3.1L, 3.4L or 3.8L engines, it may not be numbered, as is the factory coil. For this reason it is imperative that you label all wires before disconnecting any of them. Also, before removal, compare the current wiring with the accompanying illustrations. If the current wiring does not match, make notes in your guide to reflect how your engine is wired.
Fig. 3.1L (VIN M) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.4L (VIN X) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.4L (VIN E) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.5L (VIN H) engine Firing order: 1-2-3-4-5-6 Distributorless Ignition System
Fig. 3.8L (VIN 1) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
Fig. 3.8L (VIN K) engine Firing order: 1-6-5-4-3-2 Distributorless Ignition System
The firing order for the 3.1L VIN M, 3.4L VIN E, 3.4L VIN X and 3.5L VIN H engines is 1-2-3-4-5-6. The right bank cylinders are on the cowl side (rear) of the engine compartment and are numbered 1,3,5, left bank cylinders on the front side of the vehicle, are numbered 2,4,6.
The firing order for the 3.8L VIN K and 3.8L VIN 1 engines is 1-6-5-4-3-2. Starting at the front of the engine, cylinders in the left bank are numbered 1,3,5 and cylinders in the right bank are numbered 2,4,6
Hope helped (remember rated this help) Good luck.
11helpful
I need the diagram to put the spark plug cables
2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
Spark Plug Wires - Removal & Installation
3.5L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
    NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  2. Remove the intake manifold cover, if required.
  3. Disconnect the left side spark plug wires from the spark plugs.
  4. Disconnect the left side spark plug wires from the ignition coil.
  5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
  6. Remove the spark plug wire assembly.
  7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
  8. Disconnect the right side spark plug wires from the spark plugs.
  9. Disconnect the right side spark plugs from the ignition coils.
  10. Remove the spark plug wire assembly.
  11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
To install:
  1. Install the spark plug wire assembly.
  2. Connect the right side spark plugs to the ignition coils.
  3. Connect the right side spark plug wires to the spark plugs.
  4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
  5. Install the spark plug wire assembly.
  6. Connect the left side spark plug wires to the spark plugs.
  7. Connect the left side spark plug wires to the ignition coil.
  8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
  9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
  10. Install the intake manifold cover, if required.
Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
I really hope help you with this (remember rated this help) Good luck.
5helpful
Ignition firing order and cable position at the coils
The firing order for the 3.8L VIN K and 3.8L VIN 1 engines is 1-6-5-4-3-2. Starting at the front of the engine, cylinders in the left bank are numbered 1,3,5 and cylinders in the right bank are numbered 2,4,6.
I hope help you with this, remember rated this help. Good luck.
16helpful
Firing diagram for a 87 olds delta 88 3.8
1987 Oldsmobile Delta 88
3.8 liter V-6 VIN "3" Identifying Ignition Types I and II
Top McCulloch Garden Experts
Jay Finke
Jay Finke
Floyd Rogers
Floyd Rogers
Level 1 Expert
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
